Question about Kitchen Ranges
Whilrpool Self Cleaning Range Door won't unlock
Whirlpool Self Cleaning Electric Range Model RF386PXGW0:
Used Self cleaning feature and when done got error code E1-F5 and door won't unlock. I just want to get the door open, don't necessarily need self cleaning feature or door latch to work ever again, as long as oven does.
How do I get the door open??
  • 5 more comments
  • Anonymous Aug 01, 2008
    door latch not getting power.
  • gotrum Nov 23, 2008
    have the same problem on the gas range. door won't open
  • acousticmirr Jan 05, 2009
    I have the same issue coupled with a random clicking that happens when the stove isn't even being used. I tried the fix mentioned but id didn't respond in the way I'd hoped.
  • Anonymous Mar 15, 2014
    Starting self clean and door error appears... Won't clean
  • Anonymous Mar 17, 2014
    After running for 4 hours in self clean mode I stopped my Whirlpool 465. Latch is engaged and keep getting error code E5F1. Unplugged and sat overnight. Plugged back in and it is still locked and beeping. Took rear panel off and can't find solenoid. HELP!! I need to cook for my my family.
  • Anonymous Mar 21, 2014
    How do I unlock the door in my oven
    need to remove oven door to clean
    President:
  • 1,314 Answers
Try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
Sounds like your door latch switch is defective and may need to be replaced.
Posted on Feb 11, 2008
    Problem Solver:
  • 4 Answers
I tried the solution above. The switch must be bad because
the F5E1 error reappeared.
To stop the BEEPING, I lifted up the stovetop to expose the
burners. I could see the oven door latch. It was still locked.
I moved the latch to the left with my finger. It slowly released itself.
The red LOCK light went out and the beeping stopped.
This probably means that the latch did not release fully after the oven self cleaning cycle was finished.
Hope that helps get rid of the beeping for you too.
Posted on Aug 17, 2012
I'm ghetting an F-5 error code on my whilrpool oven. What does this mean? How do I fix it? Thanks for your help
Hi
Error code F5 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Admiral electric range with self cleaning oven
Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
Jan 29, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Door will not unlock after cleaning
It usually takes at least an hour or more for the oven to cool down to a "safe" temperature and then it should unlock for you. If by morning it still is not unlocked, cutting the power (circuit breaker may be easiest) for 3 minutes should reset the electronics.
Mar 26, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool rf377pxg door locked after self clean
Hello- Try this first..  Unplug for 5mins.  Plug in, set clock, and push 'clean'.  After one minute push 'cancel'.  If door motor cycles and unlocks door, you got lucky. If not, then on-site diagnostics is required to solve this problem.  Technicians call 'self-clean' the 'self-destruct' feature.  Wish the solution was easy, but this one never is.   Please acknowledge this post if informative.  Thanks- Ed
Oven door remains locked after using the oven cleaning feature
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
When I try to start the self-cleaning oven, ''door'' appears in the display, and then the display goes to F5 E1. The door doesn't even try to lock. I have a Whirlpool Self-cleaning electric range Model #...
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do I stop and open door in the self cleaning?I have a hugh mess in the oven I clean the extra stuff on the bottom what happens if it starts fire and I can not shut off and open the door.
Large spots should be cleaned BEFORE starting self clean..The self clean can not be "paused" and continued..It has to be shut down and re started..
Jul 16, 2009 | Whirlpool Accubake RF362LXTT Electric...
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
2,015 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
