Question about Baby Gear
Fuel line is closed
I just got the converters and sensors replaced and the car will not stay started when you put it in gear. the fuel line button located in the trunk is now down and will not come up. How do I get the fuel line to open again?
  • 77 Answers
Electrical problems are tough to troubleshoot. Check the wiring harnesses for damage, especially the ground wires. Also, have the battery load tested to be sure there is not a shorted cell inside. 18-volts from the alternator is too high. This may be due to a missing ground wire or a faulty internal voltage regulator.
Posted on Feb 16, 2008
My 94 full size blazer starts and idles fine in park and in neutral. When I put the truck in gear and hit the gas, it'll start, then act like it wants to die. The Catalytic converter is off, I'm...
This could be a bad ground on the ECM. When it is in park it is open loop. When you put it in gear, the ecm goes closed loop with the oxygen sensors and with no ground it dies.
Jun 11, 2017 | Chevrolet 1500 Cars & Trucks
Sputtered out and now it won't stay running; dies when put in gear.
Mass air flow , crank sensor . I wouldn't discount anything . Having a scan tool that can view engine sensor data would be a great help too , testing fuel pressure and flow and back pressure test the exhaust .
058 Engine Hard to Start or No Start Lean Fuel Condition
055 Engine Hard to Start or No Start Scan Data for EGR
057 Engine Hard to Start or No Start Ignition Module Test
007 Catalytic Converter Testing
Jun 10, 2017 | 1999 Buick Regal LS
2000 fatboy will start but wont stay running, have replaced the map sensor, crank sensor, cam sensor. Put a new ignition module and a new coil. Sounds great when it starts but wont stay running. Have
Hi Manda, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jul 28, 2012 | Harley Davidson FLSTF Fat boy Motorcycles
My Mazda 6 car stalls when I stop, also crakig, I replaced throttle body and fuel pump
When you stop if the Mazda stalls try putting the car into neutral gear and see if it still stalls. if the Mazda does not stall in neutral then the torque converter has failed and needs replacing.
Sep 15, 2011 | Mazda MAZDA6 Cars & Trucks
Starts up but will not stay idling, bad gas smell comes out of it.
Hello! The gas vapor system, which is under pressure, must be purged...Without the ability to purge fuel will not flow...This is the reason the engine will not idle...Because you smell gas vapors is an indication the vapor canis ter purge valve is either defective or has an open/broken vacuum line...Follow the vacuum diagram under the hood and trace all lines..."tired" vacuum lines will **** closed, replace any cracked, broken or soft lines...If this does not solve the problem replace the purge valve...See picture below...guru...saailer...
saailer_58.jpgpurge valve ..cost $30...Guru...saailer
Jan 02, 2011 | 1999 Dodge Durango
1991 ford ranger stalls when in gear...
sounds like a electrical problem somewere
Sep 16, 2009 | 1987 Ford Ranger
1991 Chevy Corsica Starts up and Dies 5 minutes later
Sounds like a faulty sensor. Have you changed your fuel filter? Checked all vacuum lines? Any check engine light on?
Aug 02, 2009 | 1991 Chevrolet Corsica
Stalling will not stay idling
We had the same problem, tried everything. Problem was the ceramic part of the catalic converter, wich broke in pieces and came into the exhaust, so it could not get rid of the exhaust gas....
Jan 05, 2009 | 2001 Hyundai Santa Fe
95 isuzu rode0-starts in high gear
try replacing the altonator low voltage will not let it shift.also a stoped up exaust system will cause the same problem.
Dec 12, 2008 | 1995 Isuzu Rodeo
My truck dies out when stepping on the pedal more than a third of the way
Hi.
I read your problem.
I have some ideas about that.
You are right, The pressure should stay olmost the same.
But, I'm , involved in problem with aftermarket fuel pump.
I recomend A/C delco or Carter. fuel pump.
Check the Pressure regulator, that goes in the rail of the injectors. Inside of the intake, Some times is leaking.
Check the EGR valve, The carbon make the valve no close correctly, Take it out and check the pivot, they have to stay close.
Check the ground in all around of the car, speciallity the one on the frame rear , for the fuel pump.
If after all you still have the problem, Disconect the transmission seleniod connector, and put in drive, if the problem go out.
check for short cicuit in the wires and connector a transmission..
Is there more thing, but I hope this help on someting.
Jul 04, 2008 | 1997 Chevrolet S-10 Pickup
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
