Question about Samsung SPH-M500 Cellular Phone
Samsung m500 it got washed in a washing mashin help quickly before chemicals corrode battery is removed.
  • Anonymous Aug 01, 2008
    got washed! Won't power on at all... taken it apart, to no
    avail. Everything is dry, but it won't turn on anyway.
Got the same problem here :( The phone actually powers up but the main display is messed up. Does anybody know how to remove the main display? I have removed the 2 hidden screws and tried to pry off both clear plastic display covers to no avail...
Posted on Apr 07, 2008
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
Hello.i need a help,my whirlpool 6sense washing mashine 9769b when spining do horible and loud noice! I try to find bearing but i dont cnow did my washing mashine have one.
Any front-loader machine will have a shaft and two bearings supporting the tub. You may need to remove the back to find it. Also, check to make sure that whatever supports the tub (spider attached to the tub and bearing shaft) is still intact. Some models have reputations for this spider corroding and failing in as little as 2 years.
Apr 12, 2016 | Whirlpool Washing Machines
How to clean it
You could purchase front loader washing machine cleaning chemical or soap. My experience with cleaning chemical and soap was to just masking smell, not fixing the problem. I did a few search and came out with using vinegar, baking powder and bleach is most effective way to clean and get smell out of washing machine. ie run cleaning cycle with 1 or 2 cup of vinegar, let it run for 20 ~ 30 minutes and pause for 30 minutes (it help break it up) let resume and finish cycle. Run cleaning cycle again with baking powder. If your machine don't have cleaning cycle use hot water and heavy load setting. Hope this help you.
Apr 19, 2014 | Zanussi FS1255S Front Load Washer
Samsung front load washer does nt empty water does nor run
hi! I've faced the similar problem and procleaning the trap was a solution. Meanwhile you can learn Samsung washing mashine instructions, for example here and try to find the necessary information. Samsung Washing machine user guides and owners manual
Mar 03, 2014 | Washing Machines
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
1 "D" cell battery is corroded and stuck inside.
Here are the instructions:
http://www.maglite.com/pdf/CustServ/CD_switch_repair_8_0410212004718132.pdf
If you remove the tail cap (the part that you unscrew to put the batteries in the flashlight) and the head assembly (the part that has the light bulb) you should be able to push the battery out. Wear some of those disposable latex gloves as that chemical that comes out of the batteries is very corrosive. Or at least wash your hands really well before touching anything, especially your eyes. Good luck.
Nov 16, 2010 | MagLite Mag-Lite& Flashlight
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Samsung SPH-M500 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
