Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Setting up sharp 46
Trying to set up our new 46" sharp aquos and can't get audio. have the hdtv box from optimum. can you help?
  • Anonymous Mar 28, 2014
    Go to menu and have no normal setting
    Sniper:
  • 53 Answers
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Posted on Mar 14, 2008
My Sharp Aquos lc-46d62u has audio but not video. Only a blue screen
If you are using a box of some kind remove it and the set from power for a while and then plug back to allow both to come on and reboot---blue screen usually means no signal seen..........check the other inputs on set with a dvd player etc.
Nov 02, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
The f-connector of my sharp aquos 46 tv is broken, how to fix it
This is not too hard of a fix, you must unsolder the Old one and resolder the new, you can get the Female Jack, from say Radio Shack, or any good TV, TV antenna store.Remove the back of set with it unplugged and locate socket, unsolder and then replace with new one and solder back on.
Mar 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC46lE700UN How do I adjust the audio. Manual says that the Output Select to Fixed, but it still does not allow me to adjust the audio
If the RCA audio out put is set to 'FIXED' it means the signal at the RCA jacks will not be controlled by the Volume control of the TV, but the TV speakers will still be controlled by the TV volume control, if you want to make the RCA AUDIO out to be adjustable by the TV volume control, you will have to set it to 'VARIABLE'.
Nov 03, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound from audio output This set is new.
The speakers need some kind of amplification, if you have something like a set of computer speakers connected and they are not powered they won't work, try connecting them to the headphone jack.
Let me know the set up, what kind of speakers, audio settings from the tv menu.
lone99star
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
159 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
