Question about Whirlpool RF368 Electric Kitchen Range
Oven light problem
When changing a non working bulb in the oven I noticed the filament seemed ok so tried it in a lamp and it worked. I put it back in the oven and it came on. however when I put the protective cover back on it stops working. I tried this with the new bulb and the old bulb and it repeated every time. Works fine until the protective cover goes back on then stops working all together. What is the issue? Is it ok to use without the cover?
    President:
  • Whirlpool Master
  • 2,651 Answers
Sure you can use with out back cover, sounds as if connection inside socket is loose( not making contact with bottom of light bulb securely
Posted on Feb 24, 2008
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
Both oven lights out
Are you buying hi quality oven grade lamps for this purpose that'll take the intense heat inside an oven? I wonder if they're halogen or tungsten filament lamps. Defective solder, frosty joints and/or ring fractures on lamp driving areas of a circuit board ARE indeed capable of causing problems with lamps.
Mar 16, 2014 | Dacor MCS130 Millennia Electric Single...
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
2 out of 3 brake lights dont work
If any light lights up when you apply brakes, then the brake switch is ok. The problem could be a fuse and/or a relay. or the bulbs. Those bulbs are dual filament so one filament could be bad, for stop or tail lights.
Oct 02, 2012 | 2002 GMC Envoy XL
Hi I have a stoves 720EF oven and grill, and the light bulbs need replacing. the instructions are not clear enough! It says to grasp the back edge of the light cover and move forward. There aren't any...
As you have found out the covers are made of glass and can get very hot, so don't attempt this if the oven has been on for even a little while. You may not have noticed it but in the centre of the edge of the glass cover facing you when you look in the oven, there is a small recess in the glass adjacent to the oven wall. It is probably covered up by grease etc. It is in the centre about 1cm long and about 3mm deep. You will need a screwdriver ( an old blunt one is best so there is no sharp edges) that just fits into the recess length wise and then twist it. This should start to prise the cover away from the oven wall and then you can get your fingers behind it to pull it away. Note the cut out on the edge of the glas when refitting. This is to allow for the lamp holder. When you put it back, as long as the recess is towards the font of the oven, you should be ok.
Jan 02, 2011 | Stoves 720EF Electric Double Oven
Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Feb 03, 2010 | Whirlpool Kitchen Ranges
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool RF368 Electric Kitchen Range Logo
299 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
