Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator wiring diagram
Need wiring diagram for GE frig, icemaker not working, solenoid not opening to allow water to icemaker
  • 4 more comments
  • Anonymous May 15, 2008
    overload wiring
  • dycksden Jun 12, 2008
    took the icemaker out of a GE fridge and installed into a Kitchenaid fridge freezer on top model 1995. the icemaker worked flawlessly in the GE fridge, so am confident the ice maker is not the problem. however, not so confident that the wiring has been properly connected.
    The icemaker has; green, black, white and orange wires.
    The Kitchenaid fridge has; green, black, white and tan wires.
    Comon sense would tell me to connect the green-to green, black-to-black, white-to-white, and orange-to-tan, which is what I have done.
    The water solenoid valve has a plug that connects to the valve with one connector being a dual tan wire, and the second connector containing a white wire.
    When connected the water valve does not open to allow water passage.
    Which wires are incorrectly connected?
    thanks
  • Anonymous Mar 26, 2009
    Installed new ge ice maker in my fridge when it finally came to temp the water valve over filled the icemaker alot so i shut i shut off water supply and now it does nothing i tested all componets and the all work properly have continuity on the coil at the valve but not getting any power at the valve.
  • Gary Davd
    Gary Davd May 11, 2010
    you will have 120vac at the Valve when it is calling for water from the Icemaker..
  • Anonymous Mar 14, 2014
    GE Refrigerator Model TFX25ZPBEWW Wiring Diagram
  • Anonymous Mar 20, 2014
    the condenser fan has 4 wires w,r,b&y the other side of the plug has 3 wires w,r,&r .the wires came out of the plug. I need to know how the wires match up from 1 side of the plug to the other.
  • 979 Answers
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
SOURCE:
Water slow in door & icemaker not making ice? Whirlpool frig. & freezer side by side
Check out the water source to the refrigerator. Re the icemaker - is there water in tray? If so you need a new heater assembly. No ice? - then the water solenoid is not working.
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
Sep 21, 2017 | Whirlpool Refrigerators
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
ICEMAKER LEAK ON GE TFX25VR
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 27, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Water pump for icemaker leaking, need replacement pump.
Either the inlet valve /water pump is defective, or the icemaker solenoid is shored.
Jan 30, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Ice maker stopped working (no water for ice) I replaced the water supply solenoid and plugged it back in. Ever thing worked fine except when the water valve cycled open. Water began leaking from the...
Yes, the short tube that goes from the back of the refrigerator to the icemaker can freeze up solid preventing any more water to pass thru. this is caused by a bad water valve that is slowly leaking water to the icemaker.
Jul 05, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
16,002 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
