Question about Janome Memory Craft 3000
Janome 300E Memory Craft reading .sew and .jef
The Janome reads the compact flash when it has designs in .jef. This is from my Sitchitize cd.
The Janome will not read compact flash when it has designs in .sew. This is from my Dakota Collectibles cd.
I tried putting the .sew designs on another compact flash. Still would not work.
Yes, I did format both compact flashes.
Frustrated in Toledo
  • Laura8 Feb 10, 2008
    Will try to convert the .sew to .jef. tx, lag
  • 4,102 Answers
Hi what you need to do is change the format as it is only able to process the one format.
What you can do is search online for software that converts the formay for you most of these sites are free so have a look you whould find plenty.
Alot of people have this problem but changing the format get round this ok let me know if you need further assistance ok
Posted on Feb 10, 2008
  • paul proctor Feb 10, 2008
    If you use a search engine and type convert from .sew to .jef you should find loads of sites that do this and they dont charge for doing this.
    Also try looking for convert format then this should also list a load of sites but this way you might have to look for the right site for the conversion you want let me know if you get stuck and ill assist you further ok
Can a Janome 300e take memory cards from 8000 model? Thank you.
No, the designs on a memory card for the Memory Craft 300e do not work in the MC8000, or vice versa. The designs on memory cards for the MC9500 will work in the MC300e. See http://janome.com/en/learn/software-lessons/transferring-designs/compact-flash-card-mc9700-mc9500-and-mc300e/ for some information. The physical cards appear to be the same. If you have extra space on an existing card, you could put another file onto the card with the appropriate format for the other machine.
The MC300e reads a .JEF file; the older MC8000 reads the .SEW file.
I hope this helps.
Nov 20, 2017 | Janome Sewing Machines
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
Can I use Bernina Embroidery Cards with my Janome MC9500
Getting That Embroidery Design To Your Janome ...
https://tv-sewingcenter.com/janome/getting-that-embroidery-design-to-y...
Aug 21, 2010 - The designs will then be recognized by your embroidery machine, and you will spend more .... you can use either jef or jef+ for your 11000se .... like to know what brand,size and card reader to purchase for my Janome MC 9500. ...... Bernina · Elna · Embroidery · General · Janome · Necchi · Quilting · Sewing ...
Janome MC9500 100 Stitch Sewing 5.5x8" Embroidery ...
www.allbrands.com/products/8905
Janome MC9500 5.5x7.8" Embroidery .jef Format Replaces Memory Craft MC9000 ... to creative quilting and clothing construction, your sewing projects will go ... designcards) or Compact Flash Memory Cards (as used in digital cameras). ... My set screen controls for contrast, In./Cm. designation, and other customization
Which format does my machine use? - Embroidery.com
https://www.embroidery.com/help.ec?docID=225
Dec 26, 2015 | Janome Sewing Machines
My janome mb4 won'tt open designs I send from my computer. I have had machine for a year and never had this problem
Make sure you r sending design in correct format from memory mb4 reads only .jef format
Jan 20, 2015 | Janome Sewing Machines
In embroidery mode I insert a card adapter into my machine and all I get is a "communication error" I have a Dynex card reader which works fine on my computer. I also have PQ1 compactFlash adapter that...
The solution was sooo easy.....one of my online embroidery groups suggested to put the card in my Janome and let the machine format it. It took about a minute and did not tell me what it was doing..and It worked! It put two folders on my card, Emb5 and ord#5, and I was to copy the jef files into the Emb5 folder, which I did and bingo! my Janome 9500 read the card and produced a screen with my jef files in it. I am a happy camper....I don't know if this works with all Janome machines but it did with mine.
Thanks for being here to help.
Pepsi lady
Jun 24, 2009 | Janome Memory Craft 9500 Computerized...
Windows wont read jef files
Replaced the needle then make sure it is fully insert in the needle bar tighten properly and make sure the thread is in the right loop in the bobbin hope this will help
Oct 17, 2017 | Janome Sewing Machines
Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
Apr 12, 2009 | Janome Memory Craft 9000 Computerized...
Downloading embroidary designs for the Janome MC 350E
Firstly, format your compact flash card on your embroidery machine. This is presuming you have embroidery files in your jef format your machine reads on your computer. Place your compact flash in the compact flash card reader writer connected to your computer, open the compact flash card in your computer, open the file emb5. Now you can simply copy and paste a design from your computer to your flash card. It works for me. Goodluck.
Sep 20, 2008 | Janome Memory Craft 9000 Computerized...
Kenmore 19005
The memory card cannot be over 128 mb. Also the files need to be .jef format and stored in an emb folder on the card. I hope this helps.
Aug 05, 2008 | Kenmore 19005
Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
Oct 30, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
333 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
