Question about Dell A960 All-In-One InkJet Printer
I Don't Have The Key
My printer says " Unlock Scanner then Press Power"......i dont know how to unlock it. Will you tell me how
  • Anonymous Mar 04, 2008
    UNLOCK SCANNER
  • rnrita Aug 24, 2008
    I turn the printer on, it makes a rapid clicking sound, the printer says "unlock scanner then press power off" the green thing underneath is already on "unlock."
    What should I do?
Darryl - lift up the top part of the scanner body (the silver part should separate from the black base) and let the kick-stand support the top part. Then look underneath the top part; there'll be a green tab sticking down from the top. If you look closely, you'll see little icons next to it that look like padlocks, one in an unlocked position and one in a locked position. Push the green tab away from you so that it lines up with the unlocked padlock, and that should do the trick.
Posted on Feb 14, 2008
I read several post on the issue "unlock scanner" with no luck. Here's what worked for me...
- turn off or unplug the printer
- remove the two screws underneath the control panel cover.
- gain access to the scanner device area'
- remove two screws underneath the control panel be careful not to break the clips
- Move the scanner slightly to the middle.
- Close the printer and turn on the scanner again.
good Luck
Posted on Jul 23, 2012
I just changed the ink cartridge and the printer is telling me to unlock the scanner and then press the power button, i don't know how to unlock the scanner!
It probably is unlocked, as you did this when you first set it up.
Here's a link to the setup sheet. It's in step 4.
http://www.lexmark.com/publications/pdfs/x5150/CANLAD/setupsh.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1262720929788&answerid=16777218&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2Fx5150%2FCANLAD%2Fsetupsh.pdf&productCode=LEXMARK_X5150&highlightinfo=106955010,342,345
Jan 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Lexmark x6170 How do I unlock the scanner?
This is the user manual for your printer...
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
Sep 16, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6100 will not unlock after unlock procedure is done.
Thank you for contacting Fixya.
Please ensure that the scanner is unlocked. The scanner lock is situated under the scanner bed towards the left. To unlock the scanner, please lift the scanner bed and push the red switch towards the back of the machine. Please try scanning again and let us know the results.
If the issue still persist, please follow the steps given below:
1. Press "Copy" button.
2. Press "Options" till the display reads "Set Defaults."
3. Use the "Arrow (right/left)" buttons till the display reads "Use Factory."
4. Press "Select."
Please let us know the results.
Sincerely,
Jeeth
Apr 15, 2009 | Lexmark X6170 All-In-One InkJet Printer
Unlock scanner issues
tab? what tab are we referring to? I know this printer quite well, and I'm at a loss for understanding this aspect?
Jul 22, 2008 | Dell 1600n All-In-One Laser Printer
MY lEXMARK X6180 erroe
There should be a switch on your printer that has a padalock on it, one open and one closed. Switch it to the open one, this will unlock your scanner.
Jul 05, 2008 | Lexmark X6180 Printer
Where do I find the unlock switch to unlock the scanner.
Hardware is defective. Call lexmark tech support & get a 20% discount to buy a new printer 800 332 4120
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Error Message
The scanner lock is used to keep the printer from being damaged when it is being shipped. To unlock it, just open the printer and push the scanner lock down. When you lift up the scanner unit, (like what you do to get to the cartridges) the scanner lock is on the left of the underside of the scanner unit. You can get the manual from the Lexmark Website at http://www.lexmark.com/publications/eng/x6100/index.html
Sep 17, 2007 | Lexmark X6170 All-In-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
156 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
