Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Wf 541 how to remove top and front facia
Hotpoint aquarius wf451 the start button has loosened falling into the control panel. How do I access this component from the rear to resecure?
  • Briggs big E Feb 21, 2008
    thank you we have managed to get it sorted fairly simple in the end
  • 108 Answers
To remove the Top you need to pop small torx covers on each side at the top (near to front). Then unscrew the torx each side. the top will then slide back about 5mm.
Once the top is opened you will have a major task of removing all cables from control unity behind facia and the holding screws. Depending on the damage to the button/plastic you may be able to pop the button into place. It is also possible you may need to order a new control unit from hotpoint. I believe you can order online for minimum hassle.
Posted on Feb 21, 2008
Hotpoint Aquarius WF - 541 door is locked tight and won't open
Door will not open if water is in the drum Make sure it drained first
Jan 31, 2011 | Hotpoint Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
How do i fit a drive belt on a hotpoint tumble drier
Hi, To fit the belt to your dryer you will need to remove the top of the appliance by removing the screws at the rear. Pull of the timer/control knob. Look inside the top of the t/dryer behind the control panel you will see little plastic stems which are attached to the facia panel. You need to knock these out to remove the facia. Once this is off then you can remove the the top 3 screws and the bottom 3 screws the front panel will now come off for you to place the belt on the drum and over the motor spindle. Becareful as the t/dryer will be very loose and will twist. it is easier to lay the appilance down on its back to stop everything falling about. Now you can put it back together in the reverse order....
Good luck.............
Jan 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Feb 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf 620
A fault code of F-01 normally refers to a short circuit in the control board. The best way to find out is to gain access to the service sheet located inside the machine.
Look at the back of the machine. Along the top there should be 2-4 screws the hold the top in place. Remove these screws and pull the top backward to release it from the front. Remove the top. The service sheet should be taped to one of the support arms.
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
HOTPOINT aquarious extra
try putting the drain lower worked on our WF 541
Dec 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
234 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
