Question about Dual XDVD8180 Car Video Player
Where do i connect the reverse lamp wire
No idea where to put it help me please
    Champion:
  • 227 Answers
You connect it to the light that turn on every time you shift into reverse. I believe to the negative lead, but it best to go to manufacturer site and download the wiring instruction. Goodluck.
Posted on Mar 07, 2008
Reverse lights stay on in drive 2004 buick rendezvous cxl
Backup Lamps
The TURN SIG fuse in the console fuse block supplies battery positive voltage to park neutral position switch. When the gear selector lever is in the REVERSE position, power is supplied to both of the backup lamps. The backup lamps are grounded at G401 and G402.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B2552
The body control module (BCM) controls the backup lamp relay. The BCM grounds the backup lamp relay control circuit energizing the backup lamp relay. The BCM connects directly to the center console fuse block with no external wiring between them.
DTC B2553
The body control module (BCM) controls the backup lamp relay. The BCM grounds the backup lamps relay control circuit energizing the backup lamp relay. The BCM connects directly to the center console fuse block with no external wiring between them.
Backup Lamps Always On
  1. Turn ON the ignition.
  2. Shift the gear selector lever to the REVERSE position and then to the PARK position.
Do the backup lamps turn on in REVERSE and turn off in PARK?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Remove the backup lamps relay.
Do the backup lamps turn OFF?
Go to Step 5
Go to Step 4
Repair a short in the backup lamps relay switched battery positive voltage supply circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Check the back-up lamps relay #45 in the center console fuse/relay box .
Fuse Block - Center Console
Inside of console, behind the right console access panel
Check
Jun 11, 2016 | 2004 Buick Rendezvous
Wiring for reverse switch on a 2008 ford expedition
You probably didn't do anything to the wiring ,relay contacts maybe stuck closed ,Check the relay or have it check for DTC'S
Transmission Control Module (TCM) Diagnostic Trouble Code (DTC) Chart DTC Description Action P1910 Reverse Lamp Control Circuit/Open Go To Pinpoint Test U . P1911 Reverse Lamp Control Circuit Low Go To Pinpoint Test U . P1912 Reverse Lamp Control Circuit High Go To Pinpoint Test U .
Principles of Operation
The transmission control module (TCM) sends gear status information to the PCM over the communication network. When the transmission is in REVERSE (R), the TCM energizes a relay which supplies voltage to the reversing lamps.
Oct 18, 2017 | Cars & Trucks
Brake lights and turn signals don't work. Any ideas of why they don't work? Jiffy Lube just put in new lamps and Pep Boys tightened my battery connections.
Possibly a broken connection inside the socket for the lamp. Or, one or more wires are not making connection in the connector that goes between the wiring harness and the lamps.
Nov 07, 2010 | 2004 Chevrolet Impala
Backup light problem
the sensor/switch is located on the transmission, it has 2 or more wires connected to it
Jul 04, 2010 | 1998 Ford F150 Regular Cab
Reversing lights not working on my 1.6 ford escort m reg 1994. ive checked bulbs but still nothing. someone told me about a switch but i cant find it. any help please???
There is a switch attached to the gearbox which activates the reversing lamps when you place the gearbox into reverse. This switch has two wires going to it, one wire is an ignition live feed and the other is the feed to the rear lamps. This switch is usually on the side of the gearbox but quite high up towards the top of the gearbox. You can remove this switch with no danger of losing gearbox oil and replace it. Using a test lamp (which you can buy from any auto parts store), connect the end with the clip to the body on a clean area to ensure a good electrical connection and the pointy end to each of the wires on the switch in turn. With the ignition on but the engine NOT RUNNING, one wire should be active and the other will become active when the gearbox is placed in reverse gear. If neither of the wires are active, check fuses etc. If one wire is active but the other does not become active when reverse is selected, replace the switch. If both wires do what they are supposed too, check the wiring from the switch back to the rear lamps and check for broken or disconnected wires. The switch can be accessed from underneath the vehicle. Remember that these tests are conducted with the ignition turned on but THE ENGINE NOT RUNNING....
Dec 25, 2009 | 1994 Ford Escort
I have a 98 jeep cherokee 4L 4x4 automatic and the reverse lights dont work the bulbs are good and all fuses are too? any ideas
Reverse lamp switch wiring or switch itself is defective. Mounted on trans. Run slector lever over reverse with someone watching. the back.If yhey flicker the switch is bad. Work it several times sometimes helps .
Oct 28, 2009 | 1998 Jeep Cherokee
1990 Cutlass Ciera How do I change the headlamp bulb?
Reach in behind where wiring connects to plug and simply untwist plug and remove... lamp will be attached.
Replace with new and reverse procedure to install
Note: Don't touch lamp with bare fingers...will leave finger prints and shorten lamps life..
Mar 01, 2009 | 1994 Oldsmobile Cutlass Ciera
Reversing light dosent always work
Hi ddsnail123,
What you could be dealing with here, is a bad earth connection, or just as likely, a sticking or defective reverse lamp switch ( you'll find that on the gear box. If it's a manual it will have two cables and if it's an auto, it will be on the main gear selector switch)....The other alternative is, that the lamp holders or the connectors may be corroded inside and require cleaning or replacement....
All the best Johngee10
Sep 01, 2008 | 1999 Daewoo Nubira
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Receptacles wired backwards
"Reverse polarity" is the term used to describe the condition where electrical wires are connected to the wrong terminals of a receptacle; it's a common condition that can be hazardous if the "hot" side of your electrical system gets connected to certain types of lamps or equipment. It's common because it's an easy mistake to make when hooking up wires and because receptacles work fine even when the polarity is reversed. You generally don't know the condition exists unless you look for it. If you think you're home's wiring is a bit haphazard or may contain some conditions of reverse polarity, it's a good idea to check for it. You can buy a simple circuit tester for less than $20. Just plug it into all duplex receptacles; test both the top and bottom. If you discover reverse polarity: 1) Shut off the circuit breaker that serves that receptacle (the tester's lights will go out). 2) Unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." 3) Unscrew or release the wires from the receptacle and re-fasten them to the proper terminals--white to the silver (neutral terminal and black to the brass hot terminal. The bare or green wire should connect to the green screw. 4) Put the cover plate back on, turn the circuit back on, and test the receptacle again. Note: If the tester indicates reverse polarity but the wires are hooked up to the proper terminals, call an electrician.
Jan 18, 2006 | APC MasterSwitch Power Receptacle - Power...
Dual XDVD8180 Car Video Player Logo
126 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
