Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
HOOVER STEAM VAC
CLEANING SOLUTION LEAKS OUT WHEN I PUT THE TANK IN THE VACUUM.
  • Danielleg Feb 15, 2008
    my top is not going all the way on. one side does but not the other
  • Anonymous Mar 04, 2008
    i have loose hosehow doiget to it
    President:
  • 1,673 Answers
Check the seal where the tank sits on, also is the rod inside the handle moving up and down, or is it suck down pushing the reservior asm and allowing water to keep flowing. Another is there a hose off just under where the tank sits.
Posted on Feb 13, 2008
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Automatic "shut off" not turning off
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
Feb 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
168 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
