Question about Lexmark Z1300 InkJet Photo Printer
Loading paper i am having a hard time loading paper to my printer
    Problem Solver:
  • 6 Answers
What seems to be the problem? Printer won't pull the paper in? something else? Are you loading the paper on the upper chute or the lower? lower chute is for output, upper chute is for paper supply.
Posted on Apr 11, 2008
We have a Canon 2020i printer/copier. We are having a hard time printing address labels and it keeps saying "load paper", no matter what instructions we give the machine!!
Pull out paper cassette and look where it enters, check whether the paper sensor is healthy, if broken replace it. Paper sensor is black and is like a hook
Jan 31, 2011 | Canon imageRUNNER 2020i Black and White...
Morning, Im working with a Canon All-In-One Inkjet MX300 printer. It is not allowing me to print as it keeps telling me I do not have paper loaded in the printer. I have turned it off, and back on. Even...
Hi....hard time with your Canon... It possible you have a paper jam inside you unit.. at the back you will see a endle in both side take off the tray and look for paper jam., also check where you feed the paper if you don't have anything like paper clip pencil jam it inside the feeder
Oct 16, 2010 | Canon MX300 Office All-In-One Printer
Epson Stylus CX6000 Won't Load Paper.
hmmm am afriad if u had a warrant for it just take it back to them and get a new one...plastic staffs are hard to fix.
Nov 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Paper jam
I have also had paper jams with the lex x1240, I rectified this as best as I could by using a q-tip dip in rubbing Alchohol, and clean both sets of rollers good and be vey careful when loading paper. Also try one sheet at a time if you have not already, if it doesn't do it with 1 or 2 sheets in the tray, try loading less paper, or load until the problem re-occours and you may only be able to load 25 pages in autofeed instead of 50. I know that if it does work that way you may want to pursue any warrantie actions you have, But You are definately not the first to experience this. I am sorry you are having problems I hope this can help, It's usually just to much paper loaded that cause this or dirty rollers.
Apr 08, 2009 | Lexmark X340n All-In-One Laser Printer
Paper feed
Good day Sir, If paper misfeeds or skews, or multiple sheets feed or stick together, try the following solutions.
1. Load a smaller amount of paper into a printer and make sure you use paper designed for inkjet printers. The paper is not used or damaged.
2. Before loading paper the first time, squeeze and slide the paper guide to the left side of the paper support. Load the paper vertically against the right side of the paper support.
3. Adjust the paper guide until it rests against the left edge of the paper.
note: make sure the paper does not buckle when you adjust the paper guide. to avoid paper jams.
have a nice day!
Nov 19, 2008 | Lexmark X2350 All-In-One InkJet Printer
I put a hard paper in the printer then it will not come out
ok power off then remove cartridge and then refix it.
also put tray in excat osition.
Nov 15, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper feed
Fixing paper feed problems
  • Ifthe printer is not picking up paper, check to see if there is paper inthe IN tray. If there is not, load paper into the IN tray and press thec00153917.jpg RESUME button.
  • Do not load more than 100 sheets of 20-pound paper in the IN tray. The paper stack should not exceed 10 mm or .38 inches.
  • Use the same type paper in the paper tray when you are printing.
  • Makesure that the paper width adjuster is against the left side of thestack but is not blocking the stack. Push in the paper length adjusterto make sure that the paper is fully seated in the printer. Do not pushso hard that the paper buckles.
  • Do not use paper, envelopes, or cards that are torn, buckled, have curled edges, or do not lie flat.
  • Ifusing the IN tray to load several envelopes, push the paper lengthadjuster toward the envelopes until it stops. Do not bend the envelopes.
  • Load only one envelope at a time in the single-sheet input tray and be sure that it is inserted fully into the slot.
  • Use envelopes with square flaps instead of triangular flaps, or tuck the flaps inside the envelopes.
  • Ifthe printer's paper feed rollers become covered with debris (dust orpaper fibers), clean the rollers with a soft cloth dampened with water.
  • Ifthe paper loads unevenly in the printer, one or more of the rollers onthe rear access door is missing. Remove the rear access door and checkto see if all six rollers in the door are present. If any are missing,the door assembly needs to be replaced. This is a customer replaceablepart, number C4557-60076.
  • Ifthe printer does not drop any paper from the wings to the OUT tray,remove the excess paper. The paper stack should not exceed 10 mm or .38inches.
  • Ifthe printer is sending more than a single sheet through at one time,remove the paper from the IN tray and separate any sheets that arestuck together. Reload the paper in the IN tray.
  • Ifthe printer is not ejecting paper, then turn off the printer. If yourcomputer is turned on, turn it off. Then, turn on the computer. Wait afew seconds. Turn on the printer.
    NOTE: If you continue to experience paper feed problems, try other media or paper types. Refer to the User's Manual for supported media types and specifications.
Jul 09, 2008 | HP DeskJet 710c InkJet Printer
I get a load paper message when paper is loaded
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Feb 08, 2008 | Brother MFC-7820N Laser Printer
Lexmark Z1300 InkJet Photo Printer Logo
69 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
