About wi-fi does windows have anything to do with setting up wi-fi? for instance i have a sky broadband netgear box and my computer is windows xp home edition, could i buy a laptop with windows XP,98, 2000 with built in wi-fi.could i pickup wi-fi from the computer to the laptop?
  • zbuzz1 Feb 11, 2008
    Beautifully explained in Lame Terms.Nice & Easy.
  • moccapeanut Aug 02, 2008
    i can browse with my netgear wireless router using the yellow ethernet cable with no difficulty but using my laptop to connect to the router is a big problem.
    i already used the wpa psk network key provided by my broadband provider and encountered this error: acquiring network address.
    i disabled the encryption of the router and i was able to connect and browse wirelessly!
    when i applied the wep encryption on the router, i cant make any wireless connection.
    it is confusing! the adapter is working fine, the same with the router!
    what did i missed?
  • 48 Answers
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Posted on Feb 10, 2008
My bigpond wireless elite gateway is failing and telstra no longer supplies them . They supplied a wi fi 4g advanced11 but it doesn't have Ethernet or computer ports. What can I replace the elite unit
There are lots of router suppliers out there on the internet and via amazon and ebay.
Look for a compatible broadband router, cable?
Wi-Fi included as well Ethernet connections.
All operate to agreed standards, so there should be no problem setting up the router.
Feb 13, 2015 | NetGear Computers & Internet
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Problem setting up sky broadband on windowsw xp professional
Hi Robert,
Are you aware that Windows XP will no longer be supported by Microsoft after April 2014 and will then be open to hackers worldwide, it is highly recommended to upgrade to Windows 7 on all PCs and devices. Could be Sky are ahead of the game and have already dropped XP.
Dec 04, 2013 | Microsoft Windows XP Professional for PC
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
My iphone is not connecting with internet by wi-fi with my own broadband connection at home but is connected with the internet via wi-fi with my friends broadband connection at his home
you need to check your router setting first,if its lock then you should unlock it first and then you will get connected with Wi-fi,and you can go into router setting by typing 192.168.1.1 and then it will ask username and password,type "admin" and in iphone your wifi should be on ON mode.
Sep 11, 2011 | Cell Phones
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I have a windows xp laptop computer that is not very new. I bought a netgear router and hooked it up to my desktop computer and was able to get wi-fi for my daughter on her i-pod. Now I am trying to get...
Pretty simple. It should be set to auto discovery. As long as the WiFi is working ie switched on you shoyuld find your home network pretty easiily. You do need ot knwo the SSID (the name of the network adn teh pasword. Right click on the wireless icon in teh tray to the bottom right adn show the list of netwoprk sits found. One of those should be yours. Simply 'connect' to the network adn entire the Passphrasethat was preassigned when you set up the network an it should automagically connect.
Jan 13, 2011 | NetGear WGR614 Wireless Router
I have Windows XP. I was finally able to connect the Kodak ESP 5250 with the USB cable and print. However, I can't get my computer to print wirelessly. The printer is connected to my wi-fi. Do I need to...
In Windows XP:
Start/Settings/Printers and Faxes
Right click /Properties
Check Port tab
If the printer port connect to USB, install another instance of printer, connected to WiFi
Nov 07, 2010 | Kodak ESP5250 All-In-One InkJet Printer
Apple computer, vm fusion ware, windows xp home. log on problems.
download firefox for xp and you can prob get it for apple also this should sort out your problem
Mar 13, 2009 | Microsoft Internet Explorer 7
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
