It depends on the messenger app that you are using. Some can be deleted by swiping to the left, others by tap and hold the selected message and tap the trash can or delete.
Hi, You can get the country lock code for your Motorola I885 either from your service provider or from online sites. Theunlockarena.com is where i unlocked my phone. Check it out!!
To delete text messages you go into your indox under "messages", highlight the message you would like to delete, press the menu key and select delete.
Your "memory low" message keeps coming up because your memory not only holds your messages but EVERYTHING else as well.....pics, games, ringtones, etc. Try getting rid of things you don't need to gain more space. You might want to look into getting a SD card if your phone is capable. Hope this helps you. :)
What you need to do is delete some of your old messages as your phones memory is full from all the messages if you dont want to delete any messages in your inbox just delete your sent items and your outbox and drafts..I hope this helps
hi, this is a very common problem you need to delete any inbox/ outbox/ saved messages/ sent messages/drafts delete all the messages you can and dont need to keep.
You can also free up loads of memory by deleting all the ringtones you dont use as most people never use the ringtones you get free with the phone so delete all these that your never going to use as this will free up loads of extra memory.
You can also delete and pictures on the phone that you dont want as these also take up loads of memory but the biggest use of memory is ringtones so deleting all of these will free up loads of memory allowing you to recieve hundreds of messages.
Let me know how you get on or if you need further assistance ok
This is what you are going to do, go to your inbox and before you Open the inbox messages click on the "Options" do you have the delete property on the display? If you you can now go ahead and delete per message. If this fails to work then you can go ahead and open the messages in the inbox. When you open one of the messages click on the Options to see if you have the delete property. If you do you can as well proceed to delete.
Do this and i bet you your problem would be solved.
first press menu, select messages, then press menu button again, scroll down to cleanup messages, select, then scroll down to which box you want to delete and select. done!
First you should also delete the messages and also pictures and video clips which is not much useful for you then i hope there will be much space to be used.
If any problem persits then please message me back along with the model number.
