Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32HRS10 It has a sound,but not picture.Powers, screen are ok.,but the tube without its board,has a high tension in all the pins.I tested with the cable of the multimeter.Is the tube damage? Thanks.Walter.
  • scottokey Dec 05, 2009
    sony trinatron no picture standby light continuly blinks red
  • 116 Answers
I need more info. Sound ok but no picture? Do you have displays? (Vol bar, chan #, etc).
Posted on Mar 01, 2008
How can I turn the screen voltage up?
from description you are on the right track--screen con inside will either be on the crt circuit board or on the high voltage transformer, on or the other--lots of the older Sony sets when the picture tube gets weaker need this done.
Dec 15, 2012 | Sony KV-32S42 32" TV
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
Jan 22, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I purchased my Sony KV-35S66 in Dec. 1999. The screen is black when I turn it on. Sometimes, it will show the picture for about 45 seconds, then it disappears. The audio is fine. Have the picture tubes...
No,this tv is fixable.The video board,that the board,that connected to the CRT (Tv Tube),those round pins holes that connected CRT sockets that hold the CRT(Tv Tube) and the video board together.Resolders those CRT pins sockets that connected on to the video board.Will solved the cold solders connections between the CRT pins sockets and the video board this problems,will be solved.Tries take it to a tv shop,ask them take the tv aparts,resolder the video board CRT pins hole sockets on the video board for you.The priced my guest about $35-40.They must,take tv cover out and resolder the vdieo board CRT pins holes sockets.The whole job,take about 20-30 mins.
Oct 28, 2010 | Sony KV-35S66 35" TV
Sony trinitron television , when you turn on it takes awhile for the picture to come up on screen and when it does the screen constantly blinks
Three possibilities
First it sounds like your Tube EHT ( Extra High Tension) power supply is failing.
CRT TVs need a high voltage around 30K for the tube to work. Whcih is generated in the set, if you hear clicking sound like arcking this will confirm it. Unless you are familiar with HV electronics you should not attempt to fix it since it can be dangerous.
Second possibility is the picture tube is failing.
Third possibility is there is some problem with the video circuits, to check this try connecting a VCR or a DVD to see if the picture is OK. If it is, the problem is in the video circuits.
Feb 15, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-32fs10 won't turn on...stand by light blinks continuously
No,ur power ic board converter is dead.
U need a new one.U know some Electronics repairs,open it take off the board where near the A/C cord plug in is use the parts numbers buy it from the Web.replace it that might work, if only the power prob.nothing else.
Aug 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron, no picture, sound works fine.
There are potentially dangerous high voltages present inside the set even when unplugged, so caution is required. That being said, if you can solder, you may be able to resolve this. If the picture returns with movement, it is possible that the problem is poor solder connections. Try removing the back and sliding out the main board. Resolder any connections that appear grasiny or have rings. That may resolve the problem.
Keep us posted.
Dan
Feb 03, 2009 | Sony KV-32FS13 TV
Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Dec 27, 2008 | Sony KV-32XBR85 TV
Sony kv-36fs10
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Jan 10, 2008 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
