Question about Dell Latitude D600 Notebook
D600 probs after not wanting to turn on caps lock on flashing i reset it and cleaned memory chip thing it still wont start properly now the number 9 next to caps lock is it yikes help please
    Genius:
  • 3,587 Answers
Sounds like ye old keyboard was compromised by some foreign matter. You'll need to remove it, blow it out with some compressed, air, let it dry, and then, when the moon's full, re install it(just kidding about the full moon, you can do it while it's still waxing, too. Got backup?
Posted on Feb 10, 2008
Hp 6735s GW694AV flashing caps lock light 3 times, and wont start-up, screen stays blank
Try Hp support center entering the model number remember HP in front. If no answer found there try replacing memory chip(s) Was there a problem with it keeping time just before it stopped working? Try replacing battery.
Dec 17, 2014 | HP Computers & Internet
Tip
Laptop LED Blink on Startup There are many reasons that a computer does not...
There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
Startup Symptom: LEDs blink but does not start
The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
DO THESE FIRST - Perform a hard reset.
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Identify the number of blinks or beeps
When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
Table of Sample Blink Codes
The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
Meaning of Sample Blink Codes for some EFI Notebooks:
1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
Error Condition: CPU not functional
3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS corruption failure
4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
Error Condition: Module error not functional
5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
Error Condition: Graphics controller not functional.
6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
Error Condition: General system board failure.
7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
Error Condition: BIOS authentication failure.
8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
Error Condition: Insufficient power
Common solutions for issues that cause blinking LEDs or beep tones
When the computer can boot into the BIOS, run the memory test to identify other issues.
Check for loose connections and test the memory
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
Check for loose memory modules
If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
on Mar 21, 2011 | Computers & Internet
Flashing number lock, solid cap lock, will not turn on at all
Count the number of flashes. That is the trouble code.
Jan 29, 2014 | Dell Inspiron 1526 Notebook
Caps lock "a" keep flashing on dell d600 when trying to start. Then turns off
Here is the answer. Memory Problem:http://www.laptop-junction.com/toast/content/dell-caps-lock-light-flashing-blinking
Jun 16, 2010 | Dell Latitude D600 Notebook
Dell Lat d600 laptop---9-Lock
Change the Location of the main memory , If it works then you have problems with the slot.
If it deosn't work then change your Memory!
Nov 03, 2009 | Computers & Internet
Locks up and screen freezes. Will work after I push on it.
I think 6 flashes means memory issue. You might want to try and remove and re-insert the memory. Usually found underneath in a compartment held in with 1 screw. If this don't work, I would try and purchase new memory. This would be the cheapest and first thing to eliminate.
Mar 12, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 600 Laptop, stop working.
This is generally a problem with the battery or a memory chip. Start by removing the battery and starting up on the power supply only. Dell batteries are notorious for causeing a no start. Then try removing the memory and try one chip at a time in both slots. If neither of these work, then I'm afraid you have a failed system board component, ans you will probably want to take it in for a professional diagnostics. Also, you can find a diagnostics light codes list for your machine at Dell's support site.
Aug 06, 2008 | Dell Inspiron 6400 Notebook
Dell latitude D600 problem
The flashing caps lock is an indication of a failed POWER on Self-Test (POST)
Remove the HDD, Battery, AC adapter, RAM and Modem
Press and hold power button for 15 seconds
Connect AC, see if you get any beep codes. If you do, power off, disconnect power, insert RAM, connect AC and reboot. If system boots, power off and add hard drive. If it doesn't, replace the motherboard.
If the system boots with RAM, but fails to boot with HDD, replace HDD 1st.
Jun 25, 2008 | Dell Latitude D600 Notebook
Dell latitude d600- won't boot up!!!
Try this. Press down hard on the f7 and f8 keys while trying to turn it on. Some if it does turn on then odds are that the solder joints on the bios chip (which is below the f7/f8 keys) are bad. You can try to touch it up yourself, but it is not an easy job.
As far as I can tell the d600/600m have this issue a lot.
Apr 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
217 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
