Question about KitchenAid K45SS Classic Stand Mixer
Drip cup I took the drip cup off to do a repair. It was a tight fit when I took it off now it will not stay on? Ant thoughts on how to make it tight fit.
    Problem Solver:
  • 9 Answers
Try placing a small piece of wire under the drip cup, where it won't be seen, so that it will take up some space and cause a tight fit.
Posted on Mar 25, 2008
Planetary Plummets!
go buy a bottle of lock tight also called thread locker (red bottle) and apply some then press it in place while still wet , let dry and it should stay on
Mar 20, 2017 | KitchenAid KP2671 Professional 6 Series...
Bevel gear and worm follower gear no longer stay together
they should be a tight fit as the clip is just to help retain position
if they are ment to be loose replace the clip and inspect the groove for the clip as the edges may be worn to a taper rather than a sharp edge which will allow it to be moved out under load
May 18, 2017 | KitchenAid KP2671 Professional 6 Series...
Cannot get drip cup back on my KitchenAid classic stand mixer
I had a major problem with this beauty ring for an hour too, my issue was I could get it on but it would not stay, there was grease and it was slightly odd. I bashed it, tried to stretch it, tried to bend in the top a little.
The only solution I saw was the fact there were dots of where super glue was applied, and then I thought to myself, that they had glued it. I added dots of super glue and slid it on, held for a few seconds and let the glue do its magic. I think either it had been serviced and glued before, or it just was too out of shape to click back in.
I have seen some videos of people sliding it back on tension wise, but a few drips of super glue (front back and sides) allow you to break it loose again if need be but it wont let go on you. This is obviously only going to work if you can get it flush in the first place.
May 10, 2011 | KitchenAid K45SS Classic Stand Mixer
The chrome ring on the motor head of my 4 1/2 quart Kitchen Aid stand mixer has come off. It is the ring just above the beater shaft.We have put it back on, but it keeps slipping off. Is there a...
Hi BRET, that chrome ring is called the ‘Planetary Drip Ring’ and is a compression/friction fitted piece that should stay on during normal mixer use. Its purpose is to prevent the mixer’s transmission lubrication grease/oil from dripping into your mixing bowl from the planetary drive, hence its catchy name. It should be on tightly enough that to remove it you need to gently tap the edge of the ring with a straight screwdriver at several points on the ring. Obviously something is awry. Before going to the point of replacing it, though, you might try these three remedies first.
1) The drip ring may only fit tightly on your mixer in one orientation and you just need to ‘discover’ that correct orientation. Mark the outside of the ring with a small piece of tape so you can keep track as you rotate the ring around the mixer head flange. As you attempt to seat the drip ring, if it will not stay on, then rotate the drip ring clockwise, just a bit, and repeat the process. Ideally you should find one position where the drip ring will fit securely and stay in place. Give the drip ring one final squeeze for good measure. Keep an eye on the drip ring the first few times you use the mixer to make sure it is not working loose again. If that doesn’t remedy the problem, then…
2) You might try a little friendly persuasion by gently tapping the bottom of the drip ring with a few taps of a soft faced mallet or hammer (use a piece of wood between the hammer face and the ring to protect the ring) around the ring to see it that seats it any better, and...
3) If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head flange. You can try to ‘crimp’ it at a few points around the ring with a pair of pliers so that it may grip better.
Finally, if none of these remedies work, you should order a replacement drip ring for which you’ll need the Parts List manual. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to make sure it matches your mixer.
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 26, Planetary Drip Ring, which is the part you want to order.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Jan 22, 2010 | KitchenAid K45SS Classic Stand Mixer
The metal ring (encasing the mixing unit housing) has popped off the unit. In an attempt to replace it, it will not stay in place. How can I make it so it stays in place?
Hi ILLOWA, Happy Newy Year! I believe the metal ring you are referring to is your mixer’s “Planetary Drip Ring”. The drip ring is a compression/friction fitted piece that should stay on during normal use. It should be on tightly enough that to remove it by gently tapping the edge of the ring with a straight screwdriver at several places around the ring.
If the drip ring is falling on its own, than you might try the reverse on trying to remove the ring and tap the bottom of the drip ring gently with a few taps of a soft faced mallet or hammer (use a piece of wood between the hammer face and the ring to protect the ring) around the ring to see it that seats it any better.
The ring may only fit tightly on the mixer in one orientation. Mark the outside of the ring with a small piece of tape so you can keep track of the orientations you have tried. As you attempt to seat the drip ring, if it will not stay on, then rotate the drip ring clockwise, just a bit, and repeat the process. Ideally you should find one position where the drip ring will fit securely and stay in place. Give the drip ring one final squeeze for good measure. Keep an eye on the drip ring the first few times you use the mixer to make sure it is not working loose again.
If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head where it’s attached. You can either attempt to ‘crimp’ it with a pair of pliers at a few points around the ring so that it may grip better, or you may want to order a replacement drip ring for your mixer for which you’ll need the Parts List manual. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select the file KSM90PSWH0.pdf (354.08 KB) listed under Parts List (16) (check to see that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 26, Planetary Drip Ring, which is the part you want to order.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, and reassemble your mixer.
If this solution has helped you, please rate it, thanks! – hslincoln
Jan 08, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Planetary Drip Ring will not stay on K5SS Mixer
Hi, EAGLESON: You are correct, the Planetary Drip Ring is a friction fitted piece that should stay on during normal use. It should be on tightly enough that to remove it by gently tapping the edge of the ring with a straight screwdriver at several places around the ring. If the drip ring is falling on it’s own, than you might try tapping the bottom of the drip ring upwards with a few hammer taps around the ring to see it that seats it any better (place a piece of wood between the hammer face and the ring to protect the ring).
If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head where it’s attached. You can either attempt to ‘crimp’ it with a pair of pliers at a few points around the ring so that it can grip the flange better, or you may want to order a replacement drip ring, entirely. However, do not try to ‘glue’ it on.
You will want to have the Repair Parts manual on hand to identify the correct part number for your Drip Ring. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 42, Planetary Drip Ring, (Part # 4162074), which is the part you want to order.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Finally, if you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Dec 22, 2009 | KitchenAid K45SS Classic Stand Mixer
Silver metal ring falls off how do i get it to stay on
Hi JNJ2SOME. I believe the silver metal ring you are referring to is your mixers “Planetary Drip Ring”. Is it about 5” in diameter? The drip ring is a friction fitted piece that should stay on during normal use. It should be on tightly enough that to remove it by gently tapping the edge of the ring with a straight screwdriver at several places around the ring.
If the drip ring is falling on it’s own, than you might try the reverse on trying to remove the ring and tap the bottom of the drip ring gently with a few taps of a hammer (use a piece of wood between the hammer face and the ring to protect the ring) around the ring to see it that seats it any better. If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head where it’s attached. You can either attempt to ‘crimp’ it with a pair of pliers at a few points around the ring so that it may grip better, or you may want to order a replacement drip ring for your mixer.
The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty, which it is. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select one of the files listed under Parts List (check to see it this matches your mixer model).
Dec 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Lubricant leaking from planetary gear
use a lithium based gear grease
May 24, 2009 | Food Mixers
Oil leakage
Is the oil leaking down the beater shaft?Remove the silver drip cup,3 screw's one in the midlle,one on the right and one on the left.Once you drop the drip cup if it's filled with oil then you may need the seal's in the transmission replaced.
Mar 14, 2009 | Hobart A200 Stand Mixer
Kitchen Aid KSM90 300watt Ultra Power Mixer
According to the service manual this is the drip cup and is really only held on by friction. I have not tried to take my mixer apart yet but I would think that if your drip cup is too loose, all you need to do is come up with something (string, paper, saran wrap, etc) that will not actually glue it together but will add sufficient thickness to help hold it in place.
Dec 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
90 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
