Question about Radio Shack Cinego D-1000 Multimedia Projector
Cinego stoped running
Hello
my cinego started making a screaching sound with the fan motor and now it has stoped. we changed the lamp 2 months ago and it was working fine. what do you think could be the problem?
thank you
dave R.
Murrieta, ca.
  • 53 Answers
Grrr
Posted on Apr 26, 2008
The unit squeaks whenever turned on, no matter what level the fan is blowing (Lo, Med, or Hi). Started about a week and a half ago.
A rhythmic squeak sounds like either a fan motor bearing going bad or just vibration from the unit running thats wiggling something loose inside the unit.
Jul 23, 2015 | Everstar Portable Air Conditioner Everstar
Lamps are not lasting long enough. Bought one 2 months ago and it is out already. Bought 2 in July 2010 and they only lasted 8 months.
Heat is a huge issue in these TVs, make sure you have adequate space around the tv and that it is fairly well ventilated.
also while changing the bulb, run a vacuum and get all the dust bunnies out of it, those can cause alot of problems with the airflow in the tv.
Lastly, make sure your fans are all running, without a working fan, the bulb will overheat and cause premature failure
Jun 07, 2011 | Televison & Video
Cinego is randomly shutting down
if it is overheating, blow out the projector with canned air. excessive dust keeps in the heat that the projector is trying to expell. also, make sure all of the fans are working properly. if it's cleaned out and the fans are running, you may have a main board issue.
Nov 29, 2009 | Radio Shack Cinego D-1000 Multimedia...
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Ge PSW26LSRDSS side by side the water line freezes
The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Starting problems
if this problem persists then you could check a few things on it, like on the times when its not even making a noise when trying to turn the key, use rubber/wooden object and tap the starter motor but not touching the contacts on the back. if this amkes it spring into life then it will be your starter motor if this does nothing then it will be a dodgy battery supply. does it also make like a screaching noise while trying to start? if so then definitely your starter motor
Feb 25, 2009 | 1998 Honda Civic
My cinego shuts down
There are two fans on the right side. If one stops working, the Cinego will have the symptoms you have described. You need to send it in for repair. A local Radio Shack will tell you where to send it.
Dec 02, 2008 | Radio Shack Cinego D-1000 Multimedia...
D-1000 Cinego
I would try cleaning the fan or possibly watching the fan and make sure it continues to spin nearing the 10min window. Also those fans can be intermittant or fail when the become warm or the bearings could be going bad or gawling. Is the fan noisy at all? Also the lamp could be going bad or the ballast power supply. Projectors are tricky puppys. But you may also check the safety switch near the opening for the lamp. There should be some sort of blue switch which is closed or activated when the cover for the lamp is put back on. Hope this help you out. Let me know if it does. I am trying to become and expert advisor. Thank you in advance. Jay
Jan 29, 2008 | Radio Shack Cinego D-1000 Multimedia...
Simutaneous clanking and dimming
Hello Miggs,
This sounds like a color wheel or cooling fan issue. I would take the set back and have them check the color wheel and fan assemblies.
I hope this helps
Thank you,
Shuttle83
Jan 11, 2008 | Toshiba 62HM95 62" HDTV
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
171 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
