Question about Kenmore Elite 45986 Front Load Washer
F 11 we purchased our washer nearly 2 years ago. We bought it from Sears, it was used & had been repaired by Sears. we never received an owners manual with it. It stops, usually during the rinse/spin cycle. It beeps and flashes F 11. I do not know what this means and how to fix it... can anyone help me?
  • 5,911 Answers
"F11" is a serial communications error associated with the Central Control Unit (CCU) of the washer. This is the "brain" of the washer and often referred to as the Main Control Board or Motherboard. The error code can indicate a problem with the circuit card itself, a relay sticking on the circuit card, interconnecting wiring loose, or the door latch not latching correctly. If the problem is consistent, you may want to UNPLUG the washer & remove the top by removing the three screws in the back of the washer where the top meets the back panel. Once the screws are removed, the top should slide back then lift off. The CCU is located in the center of the washer behind the wash tub. There are a series of interconnecting cables connected to the board. Try removing these connectors (ONE AT A TIME) and re-seating them to make sure they are connected properly. Check all the connectors running to the door latch assembly as well. The latch should be behind the front panel casing on the right-hand side of the door. Make sure all the connectors are snug. Then, plug the washer back in and perform a diagnostics test by selecting DRAIN SPIN, NO SPIN, and then pushing any button under OPTIONS, 4 times (it must be the SAME button, however). "C00" will display on the washer operator console as the washer will run through a series of tests. An audible "click" will be heard when the door latch locks. This indicates that the CCU is communicating with the latch and that it is locking. The washer will then COLD FILL, HOT FILL, TEST ALL THE FEATURES OF THE DISPENSER, TUMBLE, DRAIN AND SPIN. The diagnostics tests nearly ALL the major functions of the washer. If there is a problem associated with any failed component, a fault code should appear. The test, however, is not all inclusive. Especially, if the problem is intermittent. These are the hardest type of problem to troubleshoot, because the symptoms don't always show up. If the problem continues to show up and the washer fails to complete a cycle, or is inoperative, I would replace the CCU. There are several websites that you can order parts from. The board costs about $170. If you're someone that likes to do your own repairs and wants to avoid the added labor costs of a repairman, this is MODERATE in difficulty. These machines generally cost around $1600 new. A $170 circuit board is a small price to pay in comparison and still cheaper than buying a new one. Post back with comments and let me know if you wish to pursue this repair and I can give you some info on how to order the CCU and how to replace it.
Posted on Feb 10, 2008
Shakes vilontly in spin cycle.
This is a known problem with these washers. Kenmore's version is 417.44102300 which I now have the exact same problem with. It bangs loudly on spin cycle and literally jumps across the floor.
We bought ours about 6 years ago. Apparently the bearings go bad and the tub becomes loose inside the washer; also, the "spider assembly" -- the arms that turn the tub -- disintegrate over time and fall apart. These are widely known defects. The manufacturer blames the use of non-HE detergent or "too much" detergent. IOW, they blame you, the user for their use of substandard design and materials.
So, the manufacturer (Frigidaire/Kenmore) will not own up to the issue and do a recall/repair. I have read where some people call Frigidaire / Sears and demand free repair but I doubt this is very successful. You are left with the option of fixing yourself (parts can be had for $200-300 but it is an intensive and very technical repair) or get a "ServiceSmart" contract from Sears for $350 which covers all repairs for a year. And you can hope nothing else goes wrong with this model after repair. I'm not sure if the replacement parts are the same or have been improved.
If the repair exceeds $500, Sears will credit you that amount toward purchase of a new washer. So that gives you a net discount of about $150 off a new washer which you can get from any halfway decent sale at other big boxes or your local appliance retailer. I am leaning toward buying a new washer on sale for about $450 + tax -- not at Sears (had enough of their dishonesty), and not a Frigidaire family product. Looking at washers from Lowe's. Good luck.
Dec 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I've got a Sears/Craftsman 1/2 HP garage door opener. It's older, it was in the house when I bought it 11 years ago -- model #139.53600 The door will open when I press the pushbutton inside the garage,...
If you have the wall control with 3 buttons one of them is the lock button. It is not on the side. If you have it and the light in the wall control is flashing, press and hold the button with the lock icon for 3 seconds and release. If that is not the situation your receiver is bad. The receiver is inside the motor unit and is part of the logic board.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
I bought an older Model Craftsman pressure washer.Where can I get a Owner's Manual??
You should be able to go to Sears.com and request it in either pdf form or paper copy. Swing by the Sears repair center and you can also request it from them.
Aug 26, 2009 | Garden
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite gas dryer
Hello.
vegetarianGA
You said,
When I purchased my house 2 years ago, the sellers left the washer and dryer for me. They informed me of a problem with the dryer's start button not wanting to stay pressed in. They said their solutions was to use something to keep it pressed in and so I started using shipping tape for this purpose. Last night it finally stopped working - something behind the button is obviously broken (the switch). While looking for a replacement switch and an on-line service manual, I came across this site. I did order the part from Sears today and will attempt to repair the problem myself. If I cannot, I will buy a new dryer before I pay a tech $60+ to repair a 6 year-old dryer.
I did not have the model number when I called Sears but did have another number off the back of the dryer which was for the "panel control" and the number is 3979018. The sales rep did some cross-referencing and said I own model #11072932100. I was wondering if you can direct me to an on-line service manual so I will know how to replace the switch when it arrives.
Here our sponsor's site to fine what you asked me for, a service manual!
www.Manual.Pronto.com
You sound like you are right on target !
Bless You, Huuum
Please leave me a good rating before you sign off.
Thank You
Sep 05, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
