Question about Pentax Optio M20 Digital Camera
Camera problem Hi. I have a Pentax Optio M20 Digital Camera. When I hit the on/off button, the camera turns on, the lens zooms out for a second and then back in, then it shows the "Pentax Optio M" load screen, then it shows "Auto Picture" in the center and a green dot in the bottom left with the words "EV Compensation" next to the dot. While it's showing this last screen, it beeps 3 times right before the lens zooms out again then back in just before the camera turns off. I have changed the batteries multiple times. So it's not the batteries. I connected it to the computer and then hit the on/off button. It beeps twice before the red LED light in the front of the camera lights up while the removable disk window pops up on my computer, showing 2 folders ("DCIM", and "FRAME"). I click on these folders and there's nothing in them. I hit the "on/off" button on the camera again and it turns off while the removable disk window on my computer goes away. None of the other buttons on the camera seemed to do anything whether connected to the computer or not, during every phase of it's on status. What can be done to resolve this? Thank you.
  • 1 more comment
  • danmitchell9 May 31, 2008
    I had a similar problem.  Would turn the camera on...the lens goes out...it appears to be on...then the lens disappears...and the camera turns off.  Every time.  I tried the solution of holding the MENU button at the same time as the ON/OFF button when turning the camera on.  The lens goes out...but it constantly juts in and out (which it has been doing the entire time of my writing here).  Hmmm...how to to turn it...OFF...now?
  • Arex Jul 02, 2008
    Im having the same problem, It will turn on, show the exact same thing, and then turn off. I tried the solution, but then it just shows the Optio screen, and keeps moving the lens in and out, and it will not quit until the batteries are removed.
    Help?
  • Anonymous Jul 06, 2008
    When I switch the Optio M20 on the lens moves out at it appears to try to focus. The lens then goes back in and the camera switches itself off. Holding the menu button down didn't work. Holding the blue arrow button allowed picture review mode and access to menus. Even after a factory reset problem still recurs. Any ideas?
    Sniper:
  • 66 Answers
I got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
Actually, I just tried Svenby's solution again, this time holding the two buttons, then allow it to keep going. I did this maybe 5-10 times, but eventually it worked and began functioning normally.
^___^
Posted on Jul 03, 2008
2 Suggested Answers
SOURCE: Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Posted on Apr 12, 2008
Lcd screen of Pentax camera damaged, I am located at Indore, MP
Perhaps you just try to contact Pentax for this? But I think if you could buy a LCD screen, it will cost you more than a brand new camera, with better specs than your Optio M20.
So perhaps you start saving for a new camera?
May 04, 2014 | Pentax Optio M20 7MP Digital Camera with...
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Optio M20 Stuck on Zoom in and out!
you have a timing problem,the gears for your housing is out of calibration with your focus lens inside of the housing. you must take the camera apart to correct the problem.there is a flywheel type of ajustment in the top of the camera that can be turned to bring the camera back to its reset position. it is bad to keep turning on the camera as this may danage the gear that is out of time.
Sep 12, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Jan 01, 2008 | Pentax Optio S Digital Camera
Optio M20 Beeping
You certainly need to use high capacity Ni-Mah or lithium batteries. Using alkaline would have caused overheating and may therefore have damaged the board. You are right to ask is a repair worth it? Almost certainly the answer is no even if possible. There are usually no spare parts available. Go back to tech support and this time simply report the bare facts -'It wont stay on'. Say nothing about the battery situation. Depending on the age of the device you may be offered a reasonable swap out price.
Jul 14, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio M20 Digital Camera Logo
174 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
