Putting new belt on
I need to get a new belt on the washer
  • 1 more comment
  • Anonymous Feb 29, 2008
    HOW DO YOU PUT THE SEAL BACK ON THE MACHINE?
  • murgy1 May 17, 2008
    how do you put a new belt on washer hotpoint wma40
  • guzman Jun 01, 2008
    i need to know how to put a belt on
  • 552 Answers
Http://www.repairclinic.com/0100_23.asp
Try this link for a basic veiw of a machine.
Posted on Feb 11, 2008
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
I have an amana washer...Model # 8318015...The belt is broken..I have a new belt that I need to put back on, and I need directions on how to do this
take the bottom panel out(2 screws) then the upper panel out(its clips)
now the pump need to take off the shaft 3 screws then you can put the new belt in it with tention from the pully roller... try to see if there are video for that in youtube...good luck not so EZ to do :(
Jan 02, 2010 | Amana ALW480DA Top Load Washer
My wfooo hotpoint washing machine doesnt spin, the belt came off i put it back on but then it snapped when i put the washer on spin, will the washer being empty when i did this affect the belt?
Think your belt was allready on the way out and you will need a new one. Just a coincedence that it broke when it did. It came off because it was worn and stretched.
Sep 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washer wont spin
CHECK THE MOTOR COUPLING. IT MAY BE THAT. CALL YOUR REPAIRMAN AND SEE IF HE CAN FIX THE PROBLEM. IF NOT, THEN YOU NEED TO BUY A NEW WASHER. GOOD LUCK.
RODNEY
Apr 08, 2009 | Maytag PAV2300 Top Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
The black belt in the back of the washer comes off.
you have a bad bearing. does the washer sound extra load like an airplane taking off or a train coming through your house? Usually when I see a pulley wobbly it's because the rear bearing is going out in your washer. Look in your owners the bearing which is compressed from the factory in the tub...should be covered for a certain amount of time. You just have to pay for the labor. I believe the pulley is covered and the belt as well. check it out
Feb 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
MAYTAG WASHER SAV205DAWW
This calls for some dis-assembly of the washer. Are you still looking for assistance ?
Jan 01, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
735 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
