Question about SanDisk Sansa e250 MP3 Player
Problem with the wheel
When i turn the wheel clockwise to scroll down through my songs it does not always go down. somtimes it will go back and forth between 2 songs while i am turing the wheel around and around. if i keep scrolling eventually it will go down in the list. it is very anoying. what should i do?
  • mohawk7 Feb 12, 2008
    i opened up the player but i don't see anything wong with the wheel. how do you adjust it so that iy turns the other side?
    Problem Solver:
  • 10 Answers
This also worked for me. After opening the case carefully pull the black "button" off. It will pull off fairly easily. From there you will be able to see the white plastic gears. Again, carefully remove them keeping in mind the order and placement they were in. Once you get down to the metal contact disk use a cleaning solution to remove any grime that may have accumulated there. I had used alcohol. Reassemble and viola it's back to good.
Posted on Feb 24, 2008
  • 55 Answers
Open the Player and clean where the wheel turns (it may be broken) adjust it so that it turns the other side.
Posted on Feb 11, 2008
Need to learn how to use a i-pod classic
Scrolling: move your finger clockwise to scroll up, and counterclockwise to scroll down.
Select/OK: center button
Menu: goes back to previous page. hold menu to go to main menu. you may chose what items you want in this menu under settings > main menu.
Music playback screen:
to fast forward, hold '<< or >>' OR press center button once, and use the dial. clockwise to go forwards, counter to go back. when done, wait, and the diamond will dissapear.
song ratings: Hit center twice then use the dial to enter amount of stars. is saved to iTunes next sync
Shuffle: three center clicks. can shuffle by album, or song. if it is off, it plays the playlist in order.
lyrics (If applicable): four clicks in is where you can view lyrics. if you do not have lyrics for a song input from itunes, four clicks will bring you back to the main song bar.
volume: simply rotate finger clockwise (+ vol) or counterclockwise (- vol). no Center button needed. must be in music screen. (aka, now playing.)
Hold switch: while active (orange showing) buttons and scroll wheel are deactivated to prevent accidental key clicks and volume changes.
For reference and more information:
http://manuals.info.apple.com/MANUALS/0/MA630/en_US/iPod_classic_120GB_en.pdf
these are some very basics I have written, I can definitely answer any specific how-to-iPodclassic questions.
-DF5
Oct 13, 2014 | Apple Griffin iClear Crystal-Clear...
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to www.appliancehelponline.com enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Mar 05, 2010 | Jenn-Air 48" Side-By-Side Built-In...
CLUNKING NOISE DRIVERS SIDE ONLY WHEN BRAKING
look under the seat for a bottle under it -
have your front end looked at -
Check your wheels - make sure - 100% that they are not loose by getting out the tire tool and tightening them just a little bit - or a lot if real loose.
Jan 28, 2010 | 2002 Ford F250 Super Duty SuperCab
Top scroll ball dose not work
Easy fix. Turn your mighty mouse upside down. With a dry cloth, preferably microfiber or a lens cloth, rub the wheel vigorously back and forth to clean out any dust that may be stuck in the mouse.
Dec 29, 2009 | Apple Mighty MA086LL/A Mouse
I dont know how to scroll up to get to
Simply move your finger in a circular motion around the wheel counter clockwise to scroll up, and clockwise to scroll down.
I hope this helps!
Dec 25, 2009 | Apple iPod nano
The scroll wheel does not respond
Go to ebay and look under Stiletto Wheel. A guy in Maine will fix it for $24.95. I overnighted it to him on Monday and got it back on Friday. It works perfectly, well worth it.
Sep 23, 2009 | Sirius STILETTO 100 MP3 Player
Need complete operation of mp3 player with video by ELEMENT
when the song is playing just spin the wheel clockwise to turn the volume up. You can go to settings to adjust the language. and the menu button goes back to the previous screen. I hope that helps you out.
Dec 31, 2008 | Apple iPod classic MP3 Player
SanDisk Sansa e250 MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
