Question about Toshiba (MK4004GAH) 40 GB Hard Drive
Toshiba mk 4004gah
My hard drive is too slow when window starts and when multiple program are opened and make tickle noise...any solutions...
  • 185 Answers
When Windows starts up, a number of programs will start automatically. Most of them don't need to start but they do. The more programs that start up, the longer your computer will take to load everything.
The first thing to do is to get rid of all the junk in your computer. Uninstall any program you no longer want.
Clearout all your old temporary internet files.
Do a registry and adware clean.
Get rid of old documents and files, anything you do not need.
To see the programs that start when you boot up:
Click Start
Click Run
Type msconfig
Click OK
When the window opens Click Startup
You will see a vast number of programs that your computer loads each time you boot. You can uncheck a lot of them. Do a google search for startup programs before you uncheck anything. There are some good guides that will tell you what to allow to start and what you don't need. Note any unchecked program will not be deleted or uninstalled and will still work when you want them. You will need to restart your computer if you make any changes in msconfig
I would also suggest you defrag your hard drive.
Go to Start-Programs-Accessories-Syatem Tools-Defragmenter
Follow the instructions.
Do not rule out the possibility that you have a virus or some other spyware program running in the background which slows things down. Check these out too.
Posted on Feb 10, 2008
  • Palmbeach
    Palmbeach Feb 10, 2008
    One other point to think about is Memory or RAM. When to many programs are running, you can use 100% of your computers memory, this will significantly slow things down. Unfortunately, modern programs use a lot of memory and sap resources. The answer is the same, close anything you do not need. Consider upgrading the memory, it is not too difficult to do yourdelf.
Toshiba not responding
--Clean the disk space..
--Stop auto starting programs.Click Start > Run and type "msconfig" at the prompt. Click the Startup tab and look at all that junk that loads when you launch your PC.
--Clean up the registry.
--Upgrade RAM.
--Reinstall Windows. If the above tricks haven't helped, it may be time to wipe the slate clean and start again, reformatting your hard drive, reinstalling your applications, and restoring your data files from a backup.
--Upgrade your hard drive. This is a more complicated solution, but if you're reinstalling Windows (per the prior tip) you might consider upgrading to a bigger and possibly faster hard drive, too.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | Toshiba Computers & Internet
My toshiba mk 8026gax needs repaired?
Try right clicking My Computer > Properties > Tools > Error Checking > Check Now > place checks in both boxes and Start. Run when not in use. This may take some time run. Plus OS partition will require a reboot to be checked before Windows starts. Hope this does it and not the other.
Aug 29, 2012 | Toshiba MK8026GAX (hdd2191) 80 GB Hard...
I have low memory and my laptop is slow
Toshiba laptops are not intrinsically slow computers and more often than not a slow computer is caused by a software rather than a hardware problem. Computers get bogged down by running too many processes at once, having the information in the hard drive stored in different parts of the disk (fragmented) and computer virus, worm or spy ware infestations. Of course, sometimes a computer simply doesn't have the hardware to run certain programs or will have a hardware issue that needs to be fixed.
Disk Cleanup
1.Click "Start/All Programs/Accessories/System Tools/Disk Cleanup" to open the Disk Cleanup program.
2.Select the hard drive that you want to clean up if you have more than one hard drive and then click "Ok" to get started.
3.Wait for the Disk Cleanup tool to calculate how much space it will be able to save by compressing your files. Compressing the files in your hard drive will open up space that in turn helps your computer access information faster.
4.Click the "More Options" tab on the "Disk Cleanup" window that appears and then click the "Clean Up" button within the "Windows Components" section. This will allow you to select what Windows Components you want to disable. Disabling Windows Components will make your computer software by diminishing the programs that are running.
5.Click the "Clean Up" button within the "Installed Programs" section. This will allow you to select what computer programs you no longer wish to have installed on your computer and uninstall them. Uninstall programs that have not been used in a long time such as old video games to speed up your Toshiba laptop.
6.Click the "Clean Up" button with the "System Restore" section. This will delete all but the most recent of your backup files so that you don't have useless backup files taking up space and slowing down your laptop computer.
7.Click the "Disk Cleanup" tab and then select all the files from the "Files to Delete" section that you want to delete. This will delete all those files from your computer making your computer faster by freeing up memory space. Click "Ok" to delete the files and exit Disk Cleanup.
Fan
1.Blow pressurized air from a pressurized air can into the Fan slits on the bottom and side of the Toshiba laptop to clear it of dust. A dusty, dirty fan will cause speed issues on your Toshiba laptop.
2.Power off the computer, remove the battery and all external devices and then unscrew all the screws that have a keyboard picture on it.
3.Remove the keyboard from your Toshiba laptop and on the inner, upper, left hand corner, on the side of the monitor, you'll see the fan.
4.Blow pressurized air into the fan to clear the dust and then replace the keyboard, screws, battery, external devices and power the computer back on.
Processes
1.Press the "Ctrl," "Alt" and "Delete" keys on your Toshiba laptop keyboard simultaneously and then select "Start Task Manager."
2.Click the "Processes" tab and take inventory of all the processes running on your computer.
3.Right-click on each process with your Username to the right of the process name and then select "End Process." Do not end processes that are vital to your computer running properly such as explore.exe or processes that don't have your username to the right of the process name.
4.Restart your computer if you end a vital process.
Sep 15, 2011 | Toshiba Satellite A45-S121 Notebook
Good Day! I would like to ask for your help about problems regarding to my Toshiba Satellite 1801. My laptop is very slow, refreshing it takes almost 5 minutes and Opening a programs takes almost 15...
Welcome to FixYa!
here are some steps that you may follow .
1. go to start > run> type MSCONFIG
a window shall open and DISABLE all the items that are being run at START UP
here are caps
See if that helps you ?
More over have you tried installing a Anti-virus.Cause sometimes Virus make the computer slow.
, as a tip De-fragment your hard drives time to time.if virus has hit your computer try installing a fresh copy of windows and then installing Anti-virus .let me remind you when you install a copy of windows do not attempt to open any drive cause there are auto-run viruses. so you first clean your computer then go to other drives clean and safe.
Do comment if it helped you in ANY MANNER !
Apr 13, 2011 | Toshiba Computers & Internet
My dell optiflex system started acting slow. OS installed is windows 7, Ram - 4GB usable - 3GB. i re-installed the OS using the re-installaation CD provided by DELL but found no improvement. i woould...
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
Apr 07, 2011 | Dell OptiPlex 780 DT/ 780 MT/ 780 SFF...
I get a norton warning that I have high cpu usage yet Im not running any programs.My computer is running slow and doing alot of clicking noises.I have 98% available free space on my hard drive and i...
1. Try disabling some of the Startup Programs.Press the "Windows" key on your keyboard and the "R" key at the same time. When the run dialog box comes up, type "msconfig" then press OK. The System Configuration Utility will open. Go to "Startup" tab, disable all startup programs, hit OK then restart computer.
2. Test if the computer still runs slow, if it doesn't try repeating the step 1, and re-enable the startup programs one by one or you can just check on the programs that you want to automatically start whenever you start Windows. These startup programs eats your computer resources which should have been used by the computer for processing instead.
3. If you hear clicking noises from the computer it might be the computer's Hard Drive. Download and run a Hard Disk test. You can download Hard Drive Utilities from here - click this link
4. If the Hard Drive test fails then we will need to replace the Hard drive. If it passes run a full system scan using your Security software. The computer might be infected by a virus/malware which causes slow performance.
Hope this helps.
Mar 21, 2011 | Computers & Internet
Have a problem with my portege
Which version of windows please? In 98 and ME your Hard drives are NOT set to use DMA.. In Xp the power management has toggled the cpu speed down..
These ar the 2 easiest solutions..
More info needed
Oct 19, 2007 | Toshiba Portege 2010 Notebook
Toshiba (MK4004GAH) 40 GB Hard Drive Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
