Question about Honeywell HZ708 Oil Filled Radiator Heater
Honeywell HZ708 won't turn on. I would open the case to see what is going on but it has two unique screws holding it in place that I do not have a tool for. No lights come on; nothing. Any ideas?
  • 2 more comments
  • keishashipp Nov 21, 2008
    When I press the on button, an F appears on the display. It stays on for about 5 seconds and then cuts off.
  • kathomar Dec 10, 2008
    it won't turn on-it worked yesterday...I turned it off and unplugged it like I do every evening...now it just won't go on
  • Anonymous Dec 16, 2008
    There's no heat. The display is working, however, it will not heat.
  • Anonymous Dec 19, 2008
    I have the same problem
I have found one that the power cord inside the cover has burned up a mechanical splice from the cord coming in to the smaller wire going to the electronics. The only way I have to correct this problem is to replace the crimp on splice.
Posted on Feb 27, 2008
How can I remove the fan blades from my honeywell table fan? I took the 6 screws out and removed the grill already
First remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Dec 30, 2012 | Honeywell HT900 Table Fan
Honeywell quietcare humidifier won't turn on
I am surprised that this answer isn't found anywhere, including in the manual from Kaz. If yours is the same version as mine, and your lights aren't even lighting up on top, most likely your float may have gotten bound up with gunk (the float rises up when the pan is full enough of water, which enables the motor to run. It is held into place by a plastic bracket with two phillips head screws, and looks a bit like a plastic bottle with a narrow neck in a small rectangular shape (not open at top). Remove the screws and the bracket, and take out the float and clean it and the reservoir (in the base) it sits in. Reinstall, and the float should move freely. Problem solved!
Oct 13, 2012 | Honeywell QuietCare HCM-630 Humidifier
How to open fan to clean blades honeywell model
first remove the two screws on the back top of fan... then remove little cover on third screw which is located on the bottom of the outer casing.. i used a fork to poke the hole for leverage then pull it out... take out the three screws on the bottom (that hold the stand part of the fan).. now you can start removing the casing.. start to pull apart.. carefully... once you have opened one part you can use a flathead or a butter knife to pry open where there are clips on the sides.. the final clip is under the handle poke that one and your fan should be opened....
Apr 15, 2010 | Honeywell Dryers
Turns itself off after only 1-2 minutes running time.
There should be a thermoswitch. Set it to a higher level. If it already high, it is probably defective.
Feb 17, 2010 | Honeywell HZ708 Oil Filled Radiator Heater
Heater will not turn on
Is the unit level. Does it have fluid in the chamber. That is the two most common problems. Rus
Nov 07, 2009 | Honeywell HZ708 Oil Filled Radiator Heater
Broken Caster
you should still maby have a warrenty
Jun 24, 2008 | Honeywell HZ708 Oil Filled Radiator Heater
Discs won`t come off Honda
Did you remove the two phillip head retaining screws that hold the rotor to the hub? Also, if there is alot of corrosion around the center of the hub, the rotor might be stuck in place. In that case, you'll have to tap the rotor with a hammer to break it free.
May 21, 2008 | 1998 Honda Accord
Honeywell fans
There are actually *NOT* 6 phillips screws. There are 4 in an "X" fashion (at 2, 4, 6, and 12 o clock). The last two at 12 and 6 are HEX heads.
The space is *VERY* tight, so you may want to choose a small screwdriver of the correct type, lest you strip the screw completely (like I've just done) and find yourself with a fan-sized hole in your wall.
Also, it may have just been my fan, but if the phillips screws don't come out all the way (like just a little), take a flathead and push *up* from the bottom while you unscrew it. Or you could get lucky and knock them out with a few, well-placed palm strikes.
May 15, 2008 | Honeywell HT-800 Table Fan
Honeywell HZ708 Oil Filled Radiator Heater Logo
239 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
