Question about Refrigerators
Beko AP930 fridge freezer
I have recieved an error code E9 on my fridge freezer and don't seem to be able to find any info on it at all any where, it has stopped the ice dispenserf from dispensing ice or water
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
SOURCE: I havew a Beko AP930
have the same thing and it is a small sensor on the ice maker that can miss align,ours is under warranty and is being repaired its just a case of re-positioning it...ps make sure water filter is changed every 6 months
Posted on Jun 25, 2008
Richie_asg1
  • 1036 Answers
SOURCE: fault e8 displayed on beko
E8 is an Ice sensor failure (according to Beko)
From the listings, I think this is it. -
Clicky here
Beco wanted to send an engineer out with one to fit it. I'll let you guess the quote.
- It was more than £2.50 though.
Thanks for using Fixya! If this works for you, Please rate as fixya for others to follow. Thanks.
Posted on Jul 07, 2008
SOURCE: I own a Beko AP930
Just had this fault fixed on my 930. It is the ice sensor just under the ice cube tray - mine had a broken wire (from rotating several times a day for over a year!)
Fiddley but easy fix yourself with a "leggo" block connector to re join the wire if that is the fault, or ring Beko on 01923 654659 (very helpful company to deal with) for a part.
Part number 4344740185.
The other suggestion about the water filter I respectfully believe is wrong!
Posted on Jul 31, 2008
SOURCE: Beko AP930 with Error code
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
Posted on Aug 29, 2008
Why does the new fan in my Beko AP930 not come on. It worked for 30 minutes when I first installed it.
Three possibilities: 1) new fan motor failed or is jammed by something
2) power is not getting to the new fan. 3) The fan run circuitry is not getting the 'run' signal from the temperature sensing system.
Jul 23, 2014 | Beko Fridge Water Filter Ap930 Ap930x...
Why won't the new fan on my fridge freezer work
The new fan motor may have failed!. Check the power supply to the fan motor. If the fan motor was not designed for the very cold air (-20 F) it simply stuck.
Service manual for beko
go to www. fitness.manualsonline.om or www. retrevo.com or www.manualsfactory.com
God bless you
Jun 18, 2012 | Beko Fridge Water Filter Ap930 Ap930x...
Error code E3, BEKO AP930
Hi, the error code E3 on the BEKO AP930 you have a problem with the fridge thermostat open circuit....
Take care
Jul 23, 2010 | Refrigerators
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
Beko ap930 no water geting to to ice tray
For me, this problem was because the tube was blocked with ice (the part of the tube inside the machine), which is why the tube popped off the back.
Try defrosting the freezer, or pushing hot water through the pipe with a syringe
Oct 28, 2009 | Beko 24 in. D3421F Free-standing...
Fault e8 displayed on beko ap930 fridge freezer
I had the same error message and the ice cube dispenser stopped working. On examining the workings, I found that the wire that should have been connected to the ice cube tray had sheared somehow (???) - a simple splice with lots of insulation tape has apparently fixed the problem.
Jul 03, 2008 | Refrigerators
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
May 08, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
