Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart burr coffee grinder
I've had machine for 8+ years.  Gave to a friend then got a new one, which doesn't grind coffee very fine.  On finest setting I get flakes of coffee which just don't work in espresso machine.
  • ffg1377 Apr 28, 2008
    My brand new Cuisinart DBM - 8 grinder fails to grind the coffee sufficiently fine for use in our espresso machine (Olympia Crema). Is it possible to adjust or modify the burrs to grind more finely?
The best solution I have was referred to me by a mate of mine who services commercial coffee machines.
Step 1. Remove the base of the grinder... this is actually the hardest aspect of this task... as there is one tamper-proofing screw... if you can't get the correct star-hex screw driver I recommend drilling the screw out.
Step 2. Once the base is off you will see the main shaft of the grinders motor. The shaft has a star washer set in behind hew nut, the end of the shaft has a slot cut into for a flat bladed screwdriver. Hold the nut with a pair of pliers & you can adjust the shaft positioning (& hence the burr attached to the motor) by about 3mm....
You will need to experiment to find the correct level of fineness as you require.
If you need further information send me an e-mail as I'd be happy to forward more detailed instructions.
Good Luck.
Cheers.......
Dave (dave@kingkiwi.f9.co.uk)
Posted on Nov 04, 2009
Take out the bean chute, remove the burr from the bottom. Then cut a business card the size of the burr and use it as a spacer between the burr and bean chute. This will space you burrs closer together giving you a finer grind. If there is a squealing sound the burrs are touching and need to be back off a bit.
Posted on Apr 25, 2009
  • 2,039 Answers
The other one use to work good if that one does flakie coffee the setting are not right im sure you ajusted the setting fine its when they assemble the unit it not done properly go back to the store and exchange it or open it and check for the dial ajustment thanks for using fixya pierre
Posted on Feb 10, 2008
Dave's solution was AWESOME!
I just did it! Big difference!
Took 5 minutes....
Just be careful while opening it.. a small piece falls out
which is the safety.. Inserting the ground coffee recepticle depresses it.
Its just a small plastic nub/spring.
Great! Thanks Dave!!!
Posted on Sep 29, 2012
  • gmaick
    gmaick Sep 29, 2012
    Took 5 minutes....
Coffee grinder only grinds to course no matter where grind adjuster is set
From what I've read about this grinder, you should be happy that it worked well as long as it did.
I say chuck it & buy a new one!!
Apr 13, 2012 | Coffee Makers & Espresso Machines
My Cuisinart CCM-16PC suddenly decided not to burr/grind coffee. It doesn't turn on. Electrical recepticle is hot and the device is plugged in. I've cleaned all of the connections/buttons/grooves so...
Same thing happened to me about 1 year ago. I took the machine apart and determined the issue to be in the circuit board. I bypassed the board and wired the power cord directly to the motor. The machine began to work and is still operating fine. The only drawback, of course - having bypassed the circuit board and switch, you now are on full manual operation. Plug the power cord into the wall outlet and the motor spins; when you are finished grinding you have to remove the cord from the power source to stop the motor. I am OK with this - beats 35 - 50 dollars for a new grinder. Dave
Feb 28, 2011 | Cuisinart CCM-16PC Supreme Grind Automatic...
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
I have a mazzer luigi coffee grinder on which set is the best coffee you get
grinding setting is one simple operation but requires a bit patience:
1 turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest ginding) 2 from that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line 3 grind little amount of coffee only to fill one sector of dosser than test it at your machine(if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way. 4 you test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation) 5 after setting measure the grinded coffee that come out from doser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of doser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Nov 14, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
Calibrate sm 90 coffee grinder burrs
Grinding setting is one simple operation but requires bit patience:
  1. Turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest grinding)
  2. From that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line
  3. Grind little amount of coffee only to fill one sector of dosser than test it at your machine (if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way.
  4. You test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation)
  5. After setting measure the grounded coffee that comes out from dosser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of dosser.
Nov 17, 2009 | Coffee Makers & Espresso Machines
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
I need a replacement bottom burr for the cuisinart dbm-8. the bottom burr broke. all i need is a new one. can't find a place to buy it. hoping for a lead.
Give Cuisinart Customer Service a call at 1-800-726-0190. Or you can contact them via the web at www.cuisinart.com/support/us.html
They can get you the parts you need.
Hope you found this helpful. Best regards!
Jul 07, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Grind size too big even when it is set to finest
Have you used it for awhile already? You might want to try replacing the burrs ($20) if they've been used for a few years.
Feb 28, 2009 | Solis Maestro Electric Burr Grinder
Cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Sep 09, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
2,610 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
