Question about Tomtom 1D00.081 GPS Receiver
SD card with TpmTom One
I have two SD cards and when I install either one it gives me a screen showing the card coming back out with a big red X on it. Is there a special SD card that has to be used with the TomTom? I have exactly the same problem. I have just downloaded a map, and while the device says it is in there the screen just shows the card coming out with a big red cross through it.
    President:
  • 1,944 Answers
Did you try taking out and reinserting the cards?
Did you make sure that the cards are not write protected?
If you did the above, then may I suggest that you update your unit to the latest firmware.
You can also try a master reset on the unit to see if it helps.
Please let me know how it goes.
Posted on Feb 10, 2008
    Genius:
  • 3,587 Answers
That's a basic SD compatibility issue. Can you identify the maker of the cards, please? Got backup?
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    there is another possibility. Are those SD cards formatted recently? If you have something else on them, from another application, The TomTom can be a little persnickity on layering their data alongside something else. Format them first, and try it again.
AVIC-F700BT FIRMWARE ERROR CODE
Download frsh firmware from manufacturer, yours may be corrupt and use a NEW sd card, they do develop faults every now and then
Feb 18, 2014 | Pioneer AVIC-F700BT Car GPS Receiver
Motonav TN30 blue screen em "X" red
send the unit in for a warrantee repair
Techman
Apr 30, 2010 | Motorola Mobility Motonav TN30 Car GPS...
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Download maps to SD but TomTom won't read them
The OneXL can't read form internal memory and SD card at the same time.. much like a floppy disk on a computer. If it shall boot from SD card, it need the software installed as well...
May 05, 2009 | Tomtom ONE XL GPS
When I install my 2g sd card in my TT it just comes up with a screen that shows the TT unit with the sd card being removed and then it shows the sd card beside the unit with a red X over the card. I dont...
dude check it the tomtom needs an application, map, and at least one voice to work so before u start u need to formatt ur sd card to fatt 32 once u do that go to tomtom home and just update ur device an application and a ton of voices will come up grab the application and ONE voice now for the bad news when it comes to the map its a pain because they are kinda strict to be honest call tomtom support for help with the map they will walk u thru takin the map off the original sd card puttin it on the desktop then movin it to ur new sd card however sometimes there is issues wit the certifacation file this again is wher e u need tech support... use to wrk for tomtom....
Jan 20, 2009 | Tomtom ONE GPS Receiver
tomtom are wank!!!!!!!!!!!!!!!!!!1
Nov 06, 2007 | Tomtom 1D00.081 GPS Receiver
SD card problem
The most likely cause for the RED CROSS is that some files are missing or corrupted on the SD card. This can also occur if someone has accidently dragged and dropped files on the SD card. ie. if a folder or file has been accidently dropped into a different folder. For instance you could drag and drop the maps folder into the voices folder. In this case the unit wouldn't load up if you had no maps although the maps would still be on the SD card but would be in the wrong place. We all know that files on media can be damaged or become corrupted so its always worth making a GOOD BACKUP of any sd card so that should this problem arise you can reinstall the backup.
If you have no luck with your SD card , you could try borrowing a card off someone you know and make a copy of it then activate that copy by using the original activation code together with the device code. .... good luck .
My gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
May 06, 2007 | Tomtom GO 510 GPS Receiver
Tomtom 1D00.081 GPS Receiver Logo
69 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
