Question about Kitchen Ranges
Westinghouse Built-In Oven Model OLR-24
I would like to remove the oven door, without removing the whole unit from the wall.
I want to remove the door to paint it.
Present color is yellow, not a pretty sight.
Need help.
Thank you in advance.
Sam
There are two chrome hinges on the inside. You can remove the screws that hold them in place.
Do you still have this oven?
I'm looking for a thermostat replacement for mine.
Thanks
Posted on Jan 03, 2011
  • mikecano Jan 03, 2011
    I think you have to remove the little chrome hinge keeps on the lower inside.
    I'm looking for a thermostat replacement for this model.
    Thanks.
Hi, Did you ever figure out how to do this? I am facing the same problem! Thanks, PaineChristopher@aol.com
Posted on Mar 14, 2010
Can you remove the microwave separately without removing the complete oven/microwave unit? KEMS307DWH4 KitchenAid Wall Oven/Microwave combo unit
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Mar 26, 2016 | Microwave Ovens
My elderly neighbour is trying to light her Hygena Classi Oven built in when she turns the knob to the required number no gas is coming out to light it.
Hello Jean;
My name is Peter. I am a retired field service appliance technician.
There are several different components that may be at fault for this problem. The most probable is a bad gas ignitor. Your ignitor may either be broken or too weak to open the gas valve.
On built in wall ovens:
1.) Remove the oven door. Tilt it out to where is stays slightly open and lift straight up. When replacing the oven door make sure the hinges that the door mounts on are pulled slightly out to slide the door back on.
2.) Remove the cover on the bottom of the oven. You will see the gas burner and in the center of the back wall the gas ignitor.
3.) To replace the ignitor, you will have to remove the two plates below the ignitor.
Locate your oven model number. It is on a label either on the face of the oven after you open the door or on the side of the door.
Go into the internet and search; "Ignitor and your model number".
Make sure both your oven gas and electrical power are turned off before you do anything!
Mar 06, 2016 | Kitchen Ranges
Door for oven opens freely now.. im looking for a quik way to fix this issue without taking the whole unit off my wall..... Model # KEMS376BTLO
I am confused as to what issue you are having, this unit is a micro combo and which unit are you having issues with? Micro has a handle for a door release and oven has a pull door handle. Please get back to me with more information so I can assist you.
Also Model number is KEMS376 ------- starts with S or T
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 02, 2013 | Microwave Ovens
Remove oven door
Hello Eleanor Dailey - I understand that you will like instructions on how to remove the oven door, however may I please have the exact model number so I can assist you better in pinpointing you the instructions on how to do so.
Dec 15, 2012 | Frigidaire 27" Built-In Single Electric...
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
Nov 26, 2008 | Frigidaire 24" Built-in Single Electric...
Westinghouse Wall oven mod.PON 667S
Hi there.
Westinghouse have produced a modification which replaces the left and right door support channels in the front of the oven.
Call Ryan Nielson Spare Manager at Axial Appliance Servicing www.axial.co.nz
in Mt Wellington Auckland, and he can sell you the reinforced parts which cost me $27 for my oven.
I am replacing these channels myself this weekend as warranty no longer applies to our oven, but if yours is still under warranty I'd suggest that Axial will do the whole job.
Dec 16, 2007 | Ovens
Kitchen Ranges Logo
353 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
