Question about SanDisk Sansa e260 MP3 Player
No sound, just clicking
My Sansa e260 worked fine for about 8 months, I then lost the power cord and didn’t use it for about 4 months. After getting a new cord and charging it everything seems to work fine except all I hear through the headset is clicking. I have tried new headsets, that is not the problem, I have also updated the firmware, nothing has worked to date, any suggestions?
  • abakab May 27, 2008
    I, too, have run into the clicking problem with my son's Sansa e270. I have tried the following: 1) Resetting the device by holding the menu key down for 15 seconds. 2) Entering recovery mode. 3) Removing and reinserting the battery. 4) Installing the rockbox firmware.
    None of these actions helped, though installing the rockbox firmware did cause the device to make slightly different noises. When I uninstalled rockbox, the clicking returned.
  • 54 Answers
Try recovery mode. to do this just connect it to your computer and push the hold button so the orange is showing. next push and hold the record button and the power button. it should go into recovery mode.
Posted on Feb 15, 2008
Formatting my Sansa e260
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Thanks
Sep 08, 2009 | SanDisk Sansa e260 MP3 Player
Cig power/3.5 jack problem
You have to be using the wrong cable, my friends cable comes with 4 tips , i believe the 3 tips give you this problem
May 27, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk e260 froze after power up.
sounds like a firmware program problem and will have to be replaced. You could download an updated firmware but you will have to get a pc connection.
After your device is plugged in, are you able to go to  "my computer" and see a drive folder that has your device on it.
Mar 01, 2009 | SanDisk Sansa e260 MP3 Player
Alittle confused about the Sandisk Sansa e260
yes it will still charge and transfer data....but only if it has the same usb type that connects to you mp3 player...
Feb 22, 2009 | SanDisk Sansa e260 MP3 Player
Battery is too low. System shut down
Have you tried removing and replacing your battery? What about the connections and cord, are they damaged at all?
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
Jan 11, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Then:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
Pink Screen says "No Song"
Hi. It would seem that either the internal memory of your player has been corrupted or the firmware has experienced some errors. The best way to fix your player would be to either format it or re-load its firmware. Either way, you may need to re-load your music files once again. First, you would need to set your player to MSC mode by navigating the menu as follows: Menu >> Settings >> USB Mode, then select "MSC". If you have the "Rhapsody" E200 version, then select "Rhapsody" (it's the same as "MSC" mode) Next, plug your player in your computer and look for the drive letter corresponding to your Sansa. Right-click on the drive letter, then select "Format". Just make sure that the File System is set to FAT32. Click "Start" to begin the Format and follow the on-screen prompts. Since your songs came from audio CD, simply Drag-and-drop the files to your player (MSC mode is will actually work best with audio CD songs) If this does not work, then go ahead and re-load your Firmmware using this instruction I received from SanDisk technical support: Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would restore your player to normal settings.
May 16, 2007 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
