Question about Belling DB90 Electric Kitchen Range
Lack of control on hobs
Hi, I have a db90 belling electric range. 3 out of 4 hobs seem to now have no temperature control (just either fully on or off) - can anyone help determine the problem? Thanks.
  • Anonymous Jan 21, 2009
    I have this problem after only two years, previous cooker lasted 20 years. It's just another example nof the very poor quality of goods these days.
  • baylis1 Jan 27, 2009
    Yes same problem - all four elements either fully on or off.
  • Belling Master
  • 3,463 Answers
New temp regulators req'd
Posted on Dec 15, 2008
Oven getting to hot
I had the same problem before. I pulled off the oven temperature knob and adjusted a screw to calibrate the temperature. Used a micro screwdriver and a candy making thermometer
Oct 20, 2014 | Belling Freestanding 60cm Electric Ceramic...
Tip
Common faults with Belling DB90 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Can't read the dials on the oven controls - the numbers have rubbed off
I've the same problem and been looking for a replacement control facia for 12 months. I had no luck so I went to www.sail-rc.com and purchased number graphics for a couple of pound.
Dec 03, 2012 | Belling DB90 Electric Kitchen Range
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
Could someone tell me where to download a user manual for the belling db90,i cant remember how to set the clock!thanks
I have just been able to get hold of my Aunt & Uncles manual and have quickly uploaded a pdf version to my website - 2.79mb - here is the link, hope this will help you all -
http://www.pierrequevatre.com/Belling_db90_Electric_Cooker.pdf
Jan 22, 2010 | Belling DB90 Electric Kitchen Range
Convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Feb 03, 2009 | Belling DB90 Electric Kitchen Range
Main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Dec 12, 2008 | Belling DB90 Electric Kitchen Range
Cant get the ovens to work
Make sure timer is set to manual and noit auto
Belling DB90 Electric Kitchen Range Logo
956 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
