Question about Canon PIXMA MX310 All-In-One Printer
Received in Memory issue
My faxes are not printing, they are going straight to memory. I also have this coming up on screen: Recommend new B-CRT, and Recommend new C-CRT.  What does this mean? I have not discovered this message anywhere in the manual.
  • 19 more comments
  • Anonymous Feb 12, 2008
    Our faxes are going directly into memory and I can't find anything in the manual to direct me to changing this setting so that faxes will come right through. Please advise.
  • Anonymous Feb 20, 2008
    have the same problem also
  • vernvern Mar 06, 2008
    Received in memory, Reccommend new B-CRT
    Tried, resetting printer,menu, turning off and on
    HELP
  • Mary Harding Apr 01, 2008
    Installed weeks ago and no problems till now when the message comes up saying recommend new B-CRT. Can't find an explanation of this anywhere...somebody please help.
  • Anonymous Apr 17, 2008
    canon MX308 recommend new c-crt
  • audy Apr 23, 2008
    My faxes aren't printing they are going into memory and I am getting a message recommend new B-CRT
    What do I do to get this corrected?
    Audrey
  • Anonymous Apr 23, 2008
    I have a problem whit receiving fax it go directleyto memory how can I get rid of this problem it's getting out of hand. Stated about a week ago. I went to menu and tried all tree options on receiving faxes but non of them seems to be working at all.
  • Anonymous Jun 27, 2008
    I have a Canon MX310 that now will not let me send or receive (?) faxes.  I keep getting a message that the memory is busy and "recommend a new C-CRT...what ever that is.  Not in the manual.
  • jenart Jun 27, 2008
    I have the same problem on the Canon MX310.  I followed instructions (pg 54-55) in the manual to eliminate the documents stored in memory, but to no avail.  I did get it to print our the "Activity Report" listing what was in the memory.  But when I tried to call each file up to print and delete it, the message I got was memory empty.  What to do next.
  • Anonymous Sep 02, 2008
    I am recieving a message recieved in memory recommend new B-CRT.
  • Anonymous Sep 03, 2008
    Received in memory. How do I print out?
  • sofi37 Sep 08, 2008
    Is there any possibility to manage faxes stored in memory from my PC instead of the fax control pannel ?
  • Anonymous Sep 09, 2008
    fax goes to memory, does not print
  • pattie73 Sep 25, 2008
    Faxes going straight to memory
    Change B-CRT --I changed it even though it seemed unlikely that it was out
    ChangeC-CRT -there is no way this is low or out..
    Faxes wont come in and i can't use scanner
    What's up?
  • Anonymous Dec 04, 2008
    this printer is the worst hands down... Since i had this fax i had numerous problems. In three months i received one fax properly. STAY AWAY
  • Anonymous Dec 25, 2008
    I had stuff in memory but was pressing some buttons. Now I got directions on how to print from memory but there's nothing there. Is all my documents from memory gone. I printed the list and there is no more list either?
  • mingchu Dec 25, 2008
    I had stuff in memory but was pressing some buttons. Now I got directions on how to print from memory but there's nothing there. Is all my documents from memory gone? I printed the list and there is nothing on the list either?
  • cflee1 Feb 12, 2009
    same problem
  • Anonymous Mar 19, 2009
    Same Problem, went to return it today and they said: "Go to canon.com, (or.ca, can't remember) it will tell you how to fix it there." And they sent me out :l
    I figured out how to manually print it from memory, but it's a real pain after a while. Is there a way for it to print the faxes automatically instead of having to go to:
    Menu>Memory Reference>Print Memory List>Ok
    then...
    Menu>Memory Reference>Print Document> *enter TX/RX* > Ok
  • triplebee May 05, 2009
    I have the MX310 and the message of recommend new c-crt, however, I know the color ink is not low... it is basicall brand new. Any way to shake it up and fix this like with toner cartridges on big printers? Thanks for your help.
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel.
Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the
"right" arrow key once so that you get "Memory Reference" to appear on the screen.
Press the "OK" button once. It will display "Print List", but you want to "Print Document",
so press the "right" arrow key until you get to "Print Document" and press "OK."
Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document,
choose NO and press "OK" Your document will print out!!! =)
Posted on Sep 17, 2008
Thanks; it worked. Now all I have to do is get rid of the low toner message that's not actually true. Any ideas?
Posted on Aug 23, 2008
  • 4 Answers
I had the same problem with faxes storing to memory. The easiest thing to do is to press:
1. Menu
2. Memory refference
3. Print or Dump memory list.
4. Get the tx/rx (send and receive) number off of that sheet.
5. Go back to the menu and print a document from the menu.
6. It should ask what number document in the memory to print.
7. Put in the tx/rx number from the memory list sheet, and hit ok.
8. I printed everything that was in memory and was still getting the error so after they were done printing I just went back and deleted them from the memory.
Also, your ink cartdriges are labeled "B" and "C" inside the printer when you open the cover. "Recommend new B-CRT" means that you need to change the "B" cartridge. And if you get the "C" message, replace that one as well. The "CRT" stands for cartridge....incase you didn't already guess that. I fought with it for about a half hour trying to figure out what that meant. That should solve your problem.
Posted on Jan 13, 2009
Ya, I have the same problem with my MF6550. My issue is the ink isnt even close to being out.
1- can I override this
2- How do I get the faxes out of memory.
conceding to changing the print cartrige may do it.
Greg
Posted on Feb 28, 2008
  • bonneight Feb 28, 2008
    Ok, solved it for the MF6550
    hopefully this link will work
    http://www.usa.canon.com/consumer/contro...
    the solution was called "Setting [Cont.Printing] to "KEEP PRINTING"
    went to the canon web site typed in "print faxes from memory" and followed the Received in Memory - error message link
    four step solution
    Ok, link didnt do it so ill be nice,
    1. Press
    2. using arrows, scroll through to [fax settings], then OK
    3. scroll through to [5.printer settings] then OK
    4. scroll through to [3.cont.printing] then OK
    scroll through to [KEEP PRINTING]
    hope this helps someone
Hi! I called Canon about this problem. Here it goes....
C-CRT means to replace color ink cart. because it is low on ink or is out.
B-CRT means the same thing, but regards to the black ink cart.
Person I spoke to said he was not sure why they did not list this message in the manual.
Have a great day!
Posted on Apr 29, 2008
This is very annoying. My menu is different to the solutions everyone has poste. We have replaced the ink cartridges but it still rund on memory.
Posted on Sep 29, 2008
THE B-CRT MEANS TO CHANGE THE BLACK INK CARTRIDGE. YOUR FAX WILL START PRINTING ALL FAXES IN MEMORY AUTOMATICALLY. I JUST FIX THIS PROBLEM WITH MY CANON MX310.
Posted on Sep 24, 2008
No clue i got the same problem.will contact canon tomorrow
Posted on May 16, 2008
(for the PIXMA MX300)
PROBLEM SOLVED!!
Pressed menu button, then go to fax settings, then go to memory reference. Then go to memory list, and hit OK...this will give you a list of everything stored in memory. Then to print each document in the memory, go to print document in the memory reference submenu. Then enter the TX/RX No listed on the memory list.
Posted on Apr 10, 2008
On the Canon website, it says this means it wants a new ink cartridge.
B-CRT is the B cartridge, and C-CRT is the C Cartridge. B is the black one, and C is the color one. What's strange is, mine says it wants to change the color one, and we never print in color.
Posted on Feb 22, 2008
We are having the same problem. Can someone please advise on resolution
Posted on Feb 11, 2008
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
What does "received in memory recommend new b-crt" mean?
It Means-All the faxes you received now will be placed in memory,The black ink cartridge needs to be replaced.Then the faxes in memory will be printed out.
Thanks for your support
Dec 08, 2009 | Canon Office Equipment & Supplies
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Hi, I got a message: received in memory - recommend new b-crt
The b-crt is the black ink cartridge, when you put in a new one, it will print the fax for you.
Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Looks like I have an incoming fax: screen reads, "received in mem
You have the fax setting to use memory or no paper loaded.
Go to the fax menu and change it to print.
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Receiving Faxes
There is no setting to store faxes to memory by default. If the received faxes are being stored in memory, it's because the machine detects a problem that prevents it from printing them, such as no paper, or no ink. Go to this link and type "print received faxes" in the search box and click Search. You will see a number of items to review for troubleshooting your problem.
Apr 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Problem with fax Memory
This could be very simple. Check to be EXTRA sure that your USB line is NOT plugged into the fax line. (There's a little phone icon). That's what happened to me....boy am i dumb!
Oct 02, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Canon PIXMA MX310 All-In-One Printer Logo
7,168 people viewed this question
old marine
old marine
