Question about Kenmore 65924 Electric Dryer
Dishwasher problem my dishwasher runs through the cycle but it doesnt complete the spay arm cycle. It will start it but will kick off. Sometimes it will go for about 30 sec, other time only for a few sec. Everything else works fine.
    Novelist:
  • 166 Answers
If the cycle doesn't complete, check these:
1. Water-heating cycle
2. Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
 thanks for using FixYa
Posted on Feb 11, 2009
The cycle did not complete,the bottom spray arm (the tip) melted along with some plastic utensils (knife handles). Water come out of thee front door.When starting the washer again, the top and bottom spays...
The handles slipped down keeping the spray arm from rotating thus causing it to rest against the heating element. It won't wash because of the hole in the bottom spray arm. You have to replace the spray arm before nything else can be determined.
Feb 09, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
Dishes are not clean
HI, there are three different reasons why this will occur in this type of unit. inspect these areas carefully.
1. Not enough water
2.Clogged spay arms
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher. Make sure the temp is proper.
Jul 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishes not getting clean
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
1. No water
2. Not enough water
5. Not enough soap
Jun 06, 2009 | GE Dishwashers
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
1. No water
2. Not enough water
5. Not enough soap
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
My dishwasher sounds like its working but when i open it nothing
1. No water
2. Not enough water
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Dishes are not clean.. on top level the dishes seem to be steamy
1. No water
2. Not enough water
5. Not enough soap
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Kenmore 65924 Electric Dryer Logo
97 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
