Question about Belkin (F5D5231-4) Router
Connecting my ps3
Have purchased a belkin 54mbps wireless router and am trying to get my ps3 online.
have connected to pc no probs but when i try to connect my ps3 to sony online it tells me i need to download new version of sony software for the ps.
have tried to download but just get an error msg on screen(80710723)
please help
  • 178 Answers
I can help you
Posted on Feb 11, 2008
I am trying to reconnect to the internet I put a new modem in for my internet service trying to connect my router to my ps3 and it won't let me can you please tell me what i have to do. Thank You
I see that you have replaced you modem. Have you tried connecting your pc directly to the modem? If you do not have any internet connection when connected directly to the modem, you have to call your Internet Service Provider to setup your new modem. If you can access the internet using your new modem then there is a problem with the router. You have to re-setup your router to make it work.
Apr 04, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
How do i connect ps3 to belkin adsl2 modem with high speed wireless g router ? We have just changed our old belkin (cut out every time the phone rang) for this model and its working 10 times better with...
Network status can be checked in PS3 settings - it says whether the PS3 is connected to the network or not. If you see that it is OK, then you can check the router - it usually lists attached devices, also enable UPnP option if it is not ON yet.
If you have a problem with PS3 in wireless mode - try to connect it to the router with a Ethernet cable (configure PS3 network settings correspondingly) - if it works this way the problem most likely in wifi configuration either on the router or the PS3 side.
I hope this can help
Oct 05, 2009 | Belkin Computers & Internet
Belkin wireless n route only puts out 54mbps
The reasons you only get 54mbps could be: one, your networked PCs don't support N-mode and broadcast in G-mode, so that the router falls back to 54mbps.
Two, the signal strength is too low or the radio noise level is too high to allow N-mode operation at full speed.
So, after checking with the manuals and vendor brochures, you should try connecting the router with a single PC close by - say, ten feet in the same room - and check connection speed. If you can connect at 108 or 125 depending on which N mode you have (N, N+, N1...), the problem is likely to be distance, walls or noisy equipment.
If you still can't connect, double-check the configuration of both router and PC (wifi board "Advanced Properties" in Hardware Management) to check whether N mode is enabled at BOTH ends, especially "Wireless Mode" in the PC.
If it still doesn't work, I'd test it with a Belkin N USB key, for example, just to check that when router and client vendors say, "802.11N", they do indeed refer to the same thing. That's not so cut and dried a thing as one would expect. The N-mode standard was not completely defined from the start, so that many vendors jumped the gun and implemented their own "N-modes" which are often NOT compatible with each other. If you had a US Robotics router and a Yuwasa (and outdated SparkLANs, IIRC) wifi board, you'd discover that you could only attain 11 mbps - and if the USR router was set for "G only" or "G and N" instead of "B, G and N", you would get no connection at all.
Oct 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have a Belkin Wireless router and I have a PS3
Actually you don't need to forward ports when playing online games. The router should automatically locate the ports for the game because it has UPnP function. Here's what you can do. Disable the port forwarding and DMZ that you set on the router. Look for the UPnP function of the router and disable, Save it. Enable it again, then save. Now power cycle your router. If you have Static IP on the PS3 network settings, try to set it first to automatic IP and automatic DNS.
Hope that helps.
Sep 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I have G 54Mbps wireless Belkin router I was disconnected from the internet yesterday and i've couldn't connect anymore since. I tried to re setup the soft were but he CD doesnt give me the choice of...
Try unplugging the router and the cable/dsl modem if you have one. Wait 10 seconds and then plug the modem in. Wait a minute for the modem to boot back up and then plug the power to the router back in. Wait a little for the router to boot up and then reboot your computer.
Oct 07, 2008 | Belkin Computers & Internet
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Simultaneous PS3 and 'net connection probs.
Further to previous you understand correctly. The computer is using a wired connection, the PS3 connects wirelessly. Computer is windows XP. Don't know what firmware is, sorry.
Jan 12, 2008 | Zyxel P660HW-D1 Router
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
WIRELESS ROUTER
If you mean by the roadrunner that you are connect via a cable, the reason why the signal may fail and stop you from watching streamed video is that wireless is only 54mbps and not the best speed for streaming, but wired streams at 100mbps and is constant speed whereas wireless doesnt give a constant true speed of 54mbps it can reduce considerably.
Aug 05, 2007 | Belkin (F5D5231V4-SN-PD) Router...
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin (F5D5231-4) Router Logo
136 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
