Question about Kenmore 65924 Electric Dryer
Dishwasher Repair Dishwasher is a Stoves/Newhome DW616 Rotating spray arms do not always operate. This is an intermittent problem - will sometimes work normally for a few days then arms will not move at all with no water coming from them. Machine appears to go through its normal cycle. Some times cycle starts normaly and spray arms stop working part way through. My dishwasher I think is doing the same thing.
    Problem Solver:
  • 22 Answers
Don't know how old your unit is but try cleaning the screen at the bottom of your unit.
Posted on Dec 25, 2009
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Baumatic BD1631 dishwasher isn't washing the top tray. The rotating sprays are clear and hoses appear ok. The 'salt needed' warning light is on even though I've filled it with salt. Any ideas?
    Try rotating the arm manually. Check whether its freely rotating. Clean the rotating axis area.
    Check whether the pressure reaching the top spray arm hose.
    May 21, 2010 | Dishwashers
    Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
    Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
    Arms rotate by by pump pressure only. finally check the water pump also.
    May 18, 2010 | Whirlpool DU943PWK - Multiple Color...
    I have a bosch dishwasher, SHU535E05UC/14. The
    the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
    Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
    Upper two spray arms (Kitchenaid) are not rotating or spraying
    I have had a similar problem. I found that I had to remove the spray arms and dislodge food waste that had gotten stuck in the nozzles. Whenever cleaning has been insufficient, this has always made things better. A shame that Kitcheaid didn't do a better job on their screens/grinder.
    Mar 30, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
    GE dishwasher GSD2200G00WW dishes not clean
    Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
    Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
    Sep 06, 2008 | GE Nautilus 24" Built-in Dishwasher
    Dishwasher is not cleaning items very good that are on the top shelf and leaves food/grime on those items.
    open door when in operation and check spray arms are rotating. if not, jets are blocked. take spray arm out and clean
    Jul 22, 2008 | Dishwashers
    Dishwasher Repair
    It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
    Sep 10, 2007 | Dishwashers
    GE GLD6500LOOBB
    Open the door quikley while the washer is running. Is the spray arm spraying up and rotating. If not you may have a bad seal under the spray arm or a cracked one.
    May 08, 2007 | GE 24 in. GLD6500L Built-in Dishwasher
    Whirlpool ADP5966 washer tablet stiil in door
    probably that spray arms are not rotating - to check, open the door when in operation and see if arms move. if not moving, usual cause is debris in spray arm jets. (arms only rotate thro water coming out of angled jets at end.) remove arms and clean for which you need patience
    Apr 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
    Kenmore 65924 Electric Dryer Logo
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De GO PATS
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
