Question about Dell Dimension 3000 PC Desktop
Can't pull up the desktop on my computer
I had my computer on standby and when I return about in 2 hours, there was only a black monitor. I turned it off and on and I onlygot the DELL screen. The desktop never came up. The light for the HD is not on. I only have a green light for the system.
    Genius:
  • 3,587 Answers
Sounds like it;s in hibernate mode. when it starts up...go to F12...and reset the defaults on start up. got backup?
Posted on Feb 10, 2008
My Acer X3400, monitor turns black
you ned to check your power savings settings. Lower or check to see if video pulls the unit out of standby mode.
Dec 24, 2012 | Acer Aspire X3400 PC Desktop
My computer is booting then after short time it return to standby mode then the fan of processor rotate at very high speed and signal is remove from monitor
Seems like the PC has Hibernation mode turned on. After 1 hour windows will put the PC and hardrives to sleep to conserve power. If you want to disable it, here how:
  1. Open Control Panel.
  2. Double-click the Power Options icon.
  3. Within the Power Options Properties window, click the Hibernate tab.
  4. Uncheck the "Enable hibernation" checkbox to disable the feature, or check the box to enable it. This window also displays the total space required for hibernation.
Sep 19, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
When I turn my computer on it boots up just fine & monitor works. At some point, sometimes a few minutes, sometimes a few hours the monitor will go black and I get a no signal message. The system is...
would appear the system is in standby mode you could disable this
in windows 7 or vista go to
start
control panel
power options
choose when to turn display off
Sep 05, 2011 | Gateway Computers & Internet
After using my home computer for an hour or so and then leaving, but it is still on and when I return in 2 hours the screen is black and will not return to home page when mouse is touched. I have to turn...
OK you need to change your power settings. This decides what your computer will do when left for a period of time, it may be best to change everything to always on if you cant wake it up from hybernation, check here Control Panel\All Control Panel Items\Power Options
Sep 12, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
May 09, 2010 | HP w1907 LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
234 people viewed this question
Alun Cox
