Question about Dell Inspiron E1505 Notebook
Monitor issues My Dell Inspiron E1505 notebook has some sort of loose connection. I have to wiggle the screen back and forth to get it to work. There are lines on the monitor and intermittently I have no mouse or keyboard function unless I manipulate the monitor by moving it around. There is no specific position that it works in and the position changes daily. Is this something I can repair myself, or do I need to take it to a repair shop?
  • Anonymous Mar 19, 2008
    screen is blank
  • 52 Answers
Check this picture out, it tells u how to remove a part of ur lap top really easy and u can access and tighten the screws that hold ur monitor tighter. hope this helps. http://support.dell.com/support/edocs/systems/ins6400/en/sm/keylara2.jpg
Posted on Feb 10, 2008
Where is the video card located on a dell inspiron e1505? my laptop was kicked on an airplane while in its case. when I tried to power it up later all I get is lines on the screen. The screen is nt visibly...
Hello
What can you do if the laptop LCD screen gives the lines on screen? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assure the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from Dell support.
Good Luck and do rate the solution if got help
Dec 22, 2010 | Dell Inspiron E1505 Notebook
The screen on my Dell Inspiron E 1505 is dim to almost black. Looking closely I can see a little bit and when hooked up to an external monitor I can see my desktop. Is this an expensive problem to fix? ...
sounds like a specific issue with the LCD of the notebook. if the ac adapter is already connected to the system and same issue, try to adjust the brightness level of the LCD usually by pressing FN + up arrow key or FN + right arrow key. if this does not work, you can try to remove and reconnect the LCD cable to the motherboard. If all else fails, proceed to get an LCD replacement either through warranty if available, or by ordering a new LCD.
Sep 06, 2010 | Dell Inspiron E1505 Notebook
My screen goes black after a few minutes on my DELL inspiron 1505 laptop, can I connect a monitor
yes you can connect external monitor to check if this is a video card problem or an LCD problem
Feb 18, 2010 | Dell Inspiron E1505 Notebook
My dell laptop lcd splashes the OS and then goes dark. It works fine with an external monitor. I have a feeling that there is a loose connection since the top is almost falling off
Think you have answered your own problem here. If the external screen is ok, then the fault lies with the laptop screen.
Solutions..
1.) Remove keyboard top cover (download a "how to" guide if not familar with doing this)
2.) Remove screen bezel
3.) Check the inverter connections (inverter looks like a thin tube)
4.) Check cabling from motherboard to monitor /inverter for signs of fraying, tears, bare wires
5.) Check connections of the cable for damage.
If the above are ok, then you may have a damaged inverter. In any event, i'd look to repairing the damage to the loose lid, as its putting a strain on the wiring
Feb 09, 2010 | Dell Inspiron™ E1505 PC Notebook
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
2-3 inch swath of green from top to bottom of screen, in center
Might be a problem with your memory,your video driver,or the screens inverter board.
If you have more than 1 bank of memory,try removing one bank at a time and see if this corrects the problem. If so ,replace the bank that was removed when your screen works properly.
Also ,try updating the driver through the "Windows Update" service. If neither of those works, you may have a faulty inverter board.
Dec 28, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 2200 monitor issue
Could be that the monitor is going out, but it sounds more like a connector has worked loose or corroded and isn't making a good contact. Check and clean the screen connection, screen to inverter, and screen to motherboard.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Extended monitor resolution issues with gma 950 inspiron 6400 e1505
I've ran into similar problems with monitors before. Turns out that some monitors need their own driver installed in order to work with the video card, and, ?guess what?, they don't come with them. I usually find them at the manufacturer's site or driverguide.com Hope this helps, if not get back to me with the make and model and I'll do some research.
Jul 03, 2008 | Dell Inspiron E1505 Notebook
The laptop screen
This is going to be a hardware issue. Start by checking the screen connections, they sometimes work loose. If the connections are good and the problem persists, it's going to be the inverter or screen, and unfortunately, replacement is your only option.
Jun 28, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
105 people viewed this question
Alun Cox
