My hp psc 1210 all-in-one the scanner of which is not working any more - I double click the button for HP director the unit is not responding, but the printer and photocopier are working perfectly. What is the problem?
These "Experts" are ****! Thanks to Yahoo Answers I found a VERY simple solution which I had totally overlooked!! Don't uninstall / reinstall printer drivers before checking in your control panel under "Scanners and Cameras"! Make sure that your device is listed and the "Scanner and Camera Wizard" will take it from there. Next time I will go straight to Yahoo instead of this lame excuse for a "tech" site!
I just re-installed the driver and it works.
How do i fix this problem
I have the same problem. I have contact with HP support, but we have not solve the problem up to no
scanner worked on a ubuntu box. Â does not work on a mac book
This is the message I get.
An error occurred communicating with the scannong device. Please ensure that the scanning device is connected properly and try again.
It is connected properly as the printer works fine.
When I downloaded the software on another computer I am no longer able to scan on my HP 1210.
will not scan
hp psc 1210 all-in-one the scanner is not working problem, and notify you when a new solution is offered
Same as Kilat. Nothing happens when double clicking on HP Director...and the printer works perfectly
I press the scan buttom and I see the light flash when I try and scan a documenr and then nothing happens
I can make copies, but I dont know how to use the scanner. I hit hit the scan button, but I dont know where to go from there
hp psc1210 all-in-one th scanner in not with my vista
Microsoft "Vista" will not recognize the complete installation CD for my HP PSC 1210 All-In--One InkJet Printer.(printer & copier work fine)
When I double click on the Scan Document in the HP Director, I get a hp psc 1210 is disconnected. However, the printer works the copier works.
I have checked the usb cable and even put on a new one, but it still doen't work.
Elaine
psc 1210 all in one scanner not working
Yes, I bought the all-in-one mainly for the scanner too, and it stopped working just a very short time after I bought it. It still does not work. It doesn't matter how many times I install it either. It just don't work.
My 1210 printer and photocopier functions perfectly but the scanner is not working and when I click on my HP Director - the files empty so nothing happens. I really need help asap as we need to use the scanner almost every day. I have tried to load the software again but am told it's already loaded. I have 1 "plug" which is the USB port and am working off a laptop.
not being able to scan anything but everything else is working
good
I press the scanner button and it doesnot scan.
when trying to scan pictures to my computor, i get this error stating HP CUE scanning flow component problem.
My printer is working but it does not scan at all, I am trying but it is not.
scanner is nor working and i require drivers of this printer
My hp psc 1210 scanner won't work. The printer and copier work fine. My son hooked his laptop up to the scanner and it worked fine. We both run windows xp. What could b wrong?
My hp psc 1210 scanner won't work. The printer and copier work OK. My son hooked his laptop up to the scanner and it worked fine. We both run Windows XP. What could be wrong?
printer and copier work but when you click director nothing happens, and it won't open. What should i do to get the scanner to work?
hp director won't open and scanner does'nt work any more
i tried to re-install the driver but still not working
please help me
My hp
I have tried updating the drivers but it says I have the most updated information. The scanner is still not working although the printer and copier functions work fine. I even tried to use the Paint program with the scanner but the scanner option is not even available there. Please help!
the scanner wont install and it wont let me register the printer
vijay
i m trying to scan a document but unable to do so,
cant find NY SOLUTION plz resolve my issue.
thanks
my scanner won't scan anything. its not working or installing
evrything works but the scanner..keeps saying error
hp psc 1210 all in one scanner not working,printer ad photo coppier ok
my scanner wont come up how can i fix this
HP Director will not load. Printer, copier work fine. I can't install HP psc 1210 as a scanner either... can't find the file.
My scanner on my hp psc 1210 all in one won't scan wat do I do?
PRINTER and COPY works but will not SCAN,
help!!!!!
My HP PSC 1210 scanner only isn't working. Everything else does. If I move it to another computer, it works fine. The HP director isn't icon isn't working either. It won't come up when clicked on.
I have Windows 98.
scanner not working,printer copier works
I also have this problem my director is working.... but the scanner is not working an error comes up saying "unexpected internal error......" ive tryed reintalling twice but still not working. Please help.
same problem with director, reinstalling the latest driver twice didn't help
I can't find the scanner for hp psc 1210 all-in-one
i have a mac and i can't get my scanner to work. the printing function works fine.
my scanner was working perfectly, but when i moved my printer to a different apartment, the photocopier adn the printer work fine, but the scanner doesnt work at all
i connected the usb thingy with my laptop and placed the document on the hp psc 1210, and it didn't do nothing
i have loaded the sw from the instalation cd when i reinstalled the os. the hp director icon is on the desktop but does not load on double clicking. i can scan using photo and imaging icon but it creates image files also of documents and does not provide option to scan multiple pages of a document.
nita lal
I just moved to a new house. I replugged in the computer and printer. The printer and copier work fine but the scanner doesn't even show up and the hp director software isn't working either.
HP PSC 1210 all-in-one printer - moved to a different computer, downloaded software, receive a scanner connection error and cannot get the scanner to work. windows xp.
I have the same problem, everything was working fine until we had some repair done on our pc. now the scanner won't work, printer and copier work fine. I uninstalled and installed it again, but nothing worked
My problem too...my PSC 1210 printer works fine, but the computer will not recognize the scanner... WHAT now?
I ma having the same problem with another All in ONe device the 6110. the machine works fine except for the scanner .can someone make suggestions how to get it functioning?
I believe that when You double click on HP director it's not opening? am i correct?Just tell me the OS of your PC and i want to know Your Internet Explorer Version.
To know the version
open Internet explorer - >Click on Help menu ->Click on About internet Explorer.There u will find the version.Reply me with all the Information.Dont worry ,the problem will be fixed as i was an HP tech support for All in One printers for 20 months.
Thank You
