Question about Dryers
Noisy machine AEG Lavamat 35600 Tumble Dryer
Motor is running, but sound noisy and fast, and drum does not rotate. The the motor slows and the drum rotates, then it's not noisy. This happens when I first start the machine, then it sorts itself out after a few minutes.
Which part(s) do I need to replace?
Hope you can hekp.
  • Monty2 Feb 10, 2008
    Thanks for the speedy reply. I've had the machine a long time and this has only just started in the last month or so.
    I think it is more like a belt or a worn part.
    Sounds like I need to take the back off and give it a clean. Then see if it improves. Thanks
  • 983 Answers
Check whether there is any power problem...
or may be heating coil is out.... due to variation in power voltages....
or
there is some problem with motor it is not rotating in it s actual speed may be due to that you are facing this problem...
so just have check with the technician....
Posted on Feb 10, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 10, 2008
    may be drum and belt problem cant say exactly so have a check with technician.........
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well the problem is with the drum and moter connector. it got loose it spin fast because it wont spin the drum but when spin the drum then it wont slow this is the drum which make it slow spin.
all you need to disasseble and reassemble the parts and some cleaning ofcource.
  • Waqar Khurshid
    Waqar Khurshid Feb 10, 2008
    change the belt if its loose.
  • Waqar Khurshid
    yap thats what you need to clean and check the belt ofcourse
    Master:
    Sergeant:
  • 460 Answers
Dear Monty2
This requires allignment of the drum as well as the need for replacement of the belt. I am sure then u will get it done working.
Thankyou
    Master:
    Sergeant:
  • 440 Answers
Moter 1st i would say thx nick
  • nick helpap
    nick helpap Feb 10, 2008
    well u can look at belts and see if they need replacemnt ok if not moter
  • nick helpap
    ya def clean it always helps heat issues
Hi, I have an AEG T35850 tumble dryer. The motor makes a buzzing sound as it slowly gets going when empty. If it has a really hard time getting started, most of the time failing to get going.
The most likely cause is a slipping drive belt from the motor to the drum. Check the tension on the belt, but if the belt is worn, replace it. If the belt has been slipping for a period of time , it will probably be worn out.
Motor making a buzzing sound, is the motor actually turning? If so it is probably the belt.
If motor not turning, try taking the drive belt off and if the motor now runs, you may have seized drum bearings = expensive, buy a new dryer !
May 03, 2016 | AEG t35850 7kg vented tumble electric...
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
Noisy motor on AEG Lavamat model 64810 washer
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Jun 12, 2012 | AEG Washing Machines
When the dryer is turned on, it usually starts slow
Could just be the drive belt, or the motor starter is faulty.
Feb 22, 2010 | Dryers
Drum on dryer noisy when turning
Sounds like you have a bearing problem with the motor. I had to replace the motor to solve a similar problem. I was worroed that it might go on fire the noise was awful.
Jul 08, 2009 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
AEG LAVAMAT W1450 SOMETHING LOOSE IN DRUM WHEN SPINNING
Sounds like the main drum bearings have gone, if you hold the the drum and can feel up and movement or it sounds noisy or rough when you turn it by hand then it is definately bearings gone.
Unless you know what you are doing ,I would not recommend a D.I.Y. repair.
Dec 14, 2008 | AEG Lavamat W1450 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Dryers Logo
102 people viewed this question
Top Dryers Experts
