Sharp 27 inch tv model CK27S18
Set comes on for a second then shuts off. relay in ckt. does not stay on so power is lost. mabey needs programming as may be in service or standby mode.
  • bruno binelli Feb 11, 2008
    even when i short out the relay contacts the hi voltage is there and set stays on for 5 seconds and in spite of relay contacts shorted, set seems to go off . . no hi voltage and no _9 volt supply (shuts off)
    took out chassis only , no yoke attached ,chassis seems to react same way .even when shorting out relay contacts , power (-9 volt regulator supply and hi voltage) stays on longer for 5 seconds and then all power shuts off
  • 68 Answers
On some models there is an electrolytic cap.near the relay that tends to short and cause your relay to trip.That may need replacing.
Posted on Feb 10, 2008
Rca tv wont stay on turns on then blue light accross the screen then goes off in seconds
it is listed here as a 27 inch set--can you confirm the brand and model number for me ???
Mar 24, 2012 | RCA F27450 27" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
The power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Mar 27, 2009 | Sharp 27N-S100 27" TV
KEEPS CLICKING ON/OFF
i would check the main board for loose connections on the horizontal ckt
caypianan@yahoo.co0m
Sep 07, 2008 | RCA 27V530T 27" TV
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
Tv shuts off
you a probablyt enter in service mode for that tv set ,contact a service man
Dec 30, 2007 | Sharp 27C-240 27" TV
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Lost tv code
Here are some of the codes2.gif still looking for manual
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Mitsubishi TV4.gif 0093, 0150, 0178, 0019
JVC2.gif VCR 0067, 0041, 0008
JVC DVD1.gif 0558, 0623
samsung1.gif codes is 1004,1005,1006,1012,1013,1015,1017,1019
Motorola2.gif Cable2.gif Box: 5000, 5003, 5046, 5047, 5052
Comment by Gigatech, posted on Dec 10, 2007 Here is some helpful information4.gif I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device4.gif button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Jan 03, 2007 | Jensen 143307 Remote Control
Sharp television DV5165H
can you use the menu if so i go to ch select then choose auto programming on either cable or tv then the tv scans all the channels and sets accordingly
Aug 01, 2006 | Orion STV2763 27" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
