Question about Teac CD-X8 CD Shelf System
Buzz from speakers or headphone when CD is played.
The radio works fine but as soon as you press play it starts buzzing whether the cd is spinning or not.
  • noyahtzee Feb 16, 2008
    The power cable is factory and aligned like they say. It only affects the CD part not the radio.
    Thank you is it fixable?
    Master:
    Sergeant:
  • 462 Answers
This is due to improper insulation of wires or improper isolation of power unit with the rest of the unit.
Thankyou
Posted on Feb 10, 2008
  • Mohamed Ismail
    Mohamed Ismail Feb 16, 2008
    Else it is due to wear and tear of poor capacitors, if the capaciors dont filter harmonics such buzzing is prone to occur...!!!
  • Mohamed Ismail
    Mohamed Ismail Feb 17, 2008
    It is generally not fixable by a lay man.. its very rare to find technicians to solve this problem, because this due to poor design of the manufacturer...!!!
    Thankyou
How to fix buzzing in transcriber
Possibly the head has contacted dust particles, causing the buzz sound, try using a swab to clean the head.
Feb 02, 2015 | Panasonic Rr-830 Standard Cassette...
I have a Philips MCD-735/37 that ONLY buzzes, no music or pictures. Please help!?
if it sounds fine in the head phones and not though the speakers - unit has a faulty pa stage
Jul 30, 2014 | Philips MCD-735 System
Loud buzzing when turn on, no input signal
put a song onto play using either tape, vinyl, cd or mp3.
once playing follow the wires from the speaker that doesn't work bending it until you hear it crack or become clear if it does either of those it is the wire between the head unit and the output.
if not you can try attaching the speakers to a different head unit if it doenst work it could be the driver (the cone doesn't have to go to blow a speaker)
Jan 02, 2014 | Mackie MR5-MK2 5" Powered 2 Way Reference...
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
My speakers are currently turned on, at normal volume. Whether I try to play music or not, a buzzing noise comes from the speakers.
your power supply is bad for the speakers giving them to much power or there bad speakers plug some headphones up and see if it makes the buzzing if it does then you have a power problem with your computer or sound card
Mar 17, 2010 | Audio Players & Recorders
Speakers buzz with no sound
Is this only with CD, only with THAT CD, or with nothing in particular selected or playing?
Check all connections for tightness as bad cable shield connections will let emitted noise into the system. Ditto for signal or speaker cables routed near power cables, TV's, other electrical sources.
Sometimews reversing the AC power cord polarity can resolve buzz/hum.
Feb 20, 2010 | Philips HTS3440/37 System
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
When playing a DVD the owner manual says to push the CD/Aux button on the radio to get the DVD sound to play through the cars speakers. This doesn't work. We can only get the DVD sound to come through...
Make sure the headphones are powered off. If you press the CD/AUX button twice the headphone symbol should disappear and it will play through the car speakers.
Jul 30, 2008 | 2006 Pontiac Montana SV6
Buzz sound when i hook my laptop up
How many years have you had this laptop? Sad to say, if it's many years, time to replace as that would be cheaper.
Apr 29, 2017 | Sony STR-DE595 Receiver
Teac CD-X8 CD Shelf System Logo
122 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
