Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens Jam My camera (I have a EX-277) was dropped while turned on and the lens jammed. Is there anyway I can fix it myself? And if not, how much would it cost to get it fixed?
  • 2 more comments
  • beachbabyy Feb 11, 2008
    mine is too. ill try a new battery but if you find a better solution then PLEASE tell me!
  • Anonymous May 17, 2008
    camera was on and then stepped on then the lens got jammed
  • bird10 May 18, 2008
    my camera fell while it was turned on and now the lens wont open or close
  • Anonymous Apr 20, 2009
    i have the EX-277 and mine has the same problem. when i turn the camera on the lense comes out half way and makes ticking and humming noises. when i try to power down the lense doesnt go back in and close. it only goes half way.
  • 462 Answers
Dear titaniarox
The lens should either get in on replacing with new set of batteries or the best thing is to take it to a nearest electronics repair shop. We cannot predict exactly the extent of damage, it may be a simple one nor a complicated one.
Posted on Feb 10, 2008
I've had this camera for a while. but one time i just dropped it on a blanket while the lens was out and than the lens stayed open and out. but it turned off. i turned it back on and it said lens error...
The following web blog talks about lens error problems, and what you can try to get the camera working again:
Sometimes, when a lens gets bumped or dropped and hit, the gears inside the assemby can jam, strip, or break. The blog discusses what you can try to get the camera working again, but if nothing works, the camera will have to be serviced. You can take it in to a local camera repair shop, or contact Kodac support:
Get an estimate before having it repaired, since the cost of repair can often justify buying a new one.
Good luck, and hope this helps.
Feb 01, 2011 | Kodak Easyshare C813 Digital Camera
A friend of mine dropped my camera while the lens was extended. The camera now does not turn on but makes noise and attempts to turn on. The lens goes out and then back to the position it is stuck in. I...
The lens mechanism could be jammed and cause a failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre., being an expensive camera
get estimate before you decide. It will be good to have it checked at the Casio service as you do not have to run around for spares.
Nov 02, 2010 | Casio Exilim Card EX-S100 Digital Camera
Says lens error restart camera yet my lens will not close
Hi, your lens has probably been damaged , usuallly by dropping or bumping , or sand or some other particle may be jamming it. Try using a piece of photo film ( exposed negative) to search for anything that may be stuck in the lens where it telescopes out. Another "fix" is to firmly bang the corner of the camera case into the palm of your hand quickly after pushing the power button.This may loosen the jam
Oct 30, 2009 | Canon PowerShot A540 Digital Camera
I dropped my camera while it was on and the lens was extended. And I dropped it right on the lens. And now when I turn the camra off, the lens does not go back inside the camera. Everything else is fine,...
if the cams making grinding or crunching noise the lens housing gears are broke. repair usually not very economical. about 80% the cost of cam when you bought it.
Jun 04, 2009 | Casio Exilim EX-Z57 Digital Camera
Have read of same problem from numerous users on the internet. One person said this may be caused by a twisted/jammed lens. Apparently the "telescoping" lens mechanism can sometimes jam due to a drop and/or from dirt that gets in the telescoping hardware. The solution that someone gave that I read about involved telling the user to try to gently twist and/or wiggle the extended lens parts counterclockwise to try to "unjam" them. Of course that would also require having fully charged batteries, etc, before you try that, since from my experience, low battery charge results sometimes in the lens not retracting (or extending) properly also. It's worth a try anyway, since apparently your camera isn't functioning properly anyway now with its lens extended. I have a problem w/my On/Off switch not working properly, and in checking w/the Canon USA website, they wanted a minimum of $87 to "start" to attempt to fix it (whatever the problem is), and required that I pay them that much "up-front", and that I agree to whatever it then would cost in toral. I backed out and went and bought some new cameras instead, since I felt that was way too much to invest in my A70, that's already 5 years old now. Good luck w/your extended lens problem.
Jul 25, 2008 | Canon PowerShot A70 Digital Camera
Lens problem
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Jul 11, 2008 | Casio Exilim EX-S500 Digital Camera
Auto focus
I would take the lens off and then put it back on, being careful to align the registration marks on the lens barrel and the camera.  It should click into place quite firmly.  If this does not fix the problem, take it back for repair.
Apr 29, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon SD600 lens jam
I followed the directions contained in and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Casio Exilim ex-z700 - lens wont open
Chances are you are not going to succeed. Water dissolves Coke but Kills cameras. Dropping them does the lens drive mechanism no good at all. Well now you are in a rock and a hard place. 1st thing to do is to go and buy the next camera. Then remove batteries and memory card from the existing camera and wet a tissue and wrap it around the lens barrel and let it stand face down for a couple of hours. Then find a poly bog. and in it put some salt or uncooked rice wrapped in a cloth[hanky?] Put hanky and camera in the bag close tight shut for a day. The idea is to draw out the moisture But I reckon you will need that new camera. As for a repair -forget it - these things don't get repaired
Aug 06, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
130 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
