Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
Printer error i have a brother printer mfc-845cw and i need a new cart where do i buy one at and how do i take the printer apart to do that?
  • 832 Answers
In a store near your home? or at eBay? or from brother homepage?
Why will you take the printer apart? The cart holder is at the right front side behind a clap (where the sticker shows you the innobella carts ;-))
Posted on Feb 10, 2008
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
Unable to print 51, Brother MFC-845CW
Error code #51 - encoder strip may be stained with ink, purge cam shaft broken.
Note: error codes for inkjet printers are different than lasers.
Aug 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
"No Cartridge" error on Brother MFC-845cw
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Jan 04, 2008 | Brother MFC-845CW multi-function...
Error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Dec 29, 2007 | Brother MFC-845CW multi-function...
MFC 640CW not refilling with new ink cart.
Unplug printer from power. Wait a minute. Take all carts out. Plug machine to power. mfc demands carts. Reinsert carts (have a look if they all filled with ink!!). If asked press 2 (No change) despite you use a new cart press 1 Yes cart changed.
Should work!
Nov 03, 2007 | Brother MFC-640CW All-In-One InkJet...
Can I have an advise?
Look out for a mfc 240c sale. You will find them quite cheap because brother has put the brand new mfc 235c or 26oc on the market which are exactly the same...
In case you have a network buy a mfc 440cn (old one) the new one is the mfc 465cn and also the same.. :-)
Do use only original brother ink carts. You might find quite cheap original carts at eBay.
Nov 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
