Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Very loud fan!! Sounds like jet engine and make the computer shutoff.
I have had my pavilian ZV5000 for about 3 years and the fan runs constantly, never shuts off and most times is louder than the TV. The fan goes nuts even when the computer is just powered on and I am not doing anything with it. I called HP and they want $250 just to look at it. Anyone else run into this? Thanks
  • Rob5150 Feb 10, 2008
    Which modes are they?
  • Anonymous Mar 13, 2008
    i have the same problem, have had the same laptop for about 3 years and the fan is nuts. Recently it has begun overheating pretty often anyway, in which case it shuts off/dies without notice.
    Problem Solver:
  • 5 Answers
You need to take out the heatsink to cleanup the clogged area. The heatsink is one piece and it is held by 4 screws. Once you removed the dirt, you could tell the fan is a lot quiter.
Posted on May 20, 2009
Ive had this problem and what i did was i opened the back and cleaned out the fans...this solved the problem of overheating...but sometimes it can be a little loud still
Posted on Apr 09, 2008
    Master:
    Sergeant:
  • 462 Answers
Dont worry Rob5150, this is normal in hp laptops, this should not be bothering u any more. But there are modes in which u can make the fan run either always ON or when required.
Thankyou
Posted on Feb 10, 2008
Have a question.. I own a gateway desktop.. and just recently I left over the weekend for a camp trip.. came back to computer death.. When I initially tried turning it on.. it ran for 3 seconds each time I...
It seems like the MOBO or RAM sticks,because if the PSU is bad you cant hear any fans working.If is 5 yrs old and you dont had spare parts to rebuild it the better scenario is to buy a new one.
Jul 15, 2013 | Computers & Internet
Fan is extremely loud and sounds like a jet engine
there are 3 speeds for that fan sounds like its at the highest speed might be a relay problem or a temp sensor problem. and that fan isn't 800.00 dollars someone is kidding you call a parts place yourself. although there should be no reason to replace it this time
Apr 15, 2013 | Chrysler 2003 PT Cruiser GT
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Jul 02, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
My rav4 sounds like a jet engine. a constant whine
i am thinking might be fan belt is slackening ,u need to tighten the belt up
Nov 06, 2009 | 1998 Toyota RAV4
Loud air intake engine noise on startup
I would guess it is the electronic fan clutch. It will cause the fan to run too fast (very loud) and the light will come on sometimes.
Nov 10, 2008 | 2002 GMC Envoy XL
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
In side you're ZV5000 are two fans. These fans sit on a spindle which spins. The spindle may be worn which is giving you that loud noise. (Or a fan blade could be bent or warped from heat).
The fan it’s self may be loose & can be tightened.
The only way to check if the spindle is worn would be to dissemble the ZV5000. With the correct instruction you can check the fans. (And also clean the fans & copper heat sinks).
Here is a link to do this you're self, including pictures.
http://www.instructables.com/id/Cleaning-Your-Laptop-Cooling-System/
It's worth taking a look & saving you're self a few bucks.
Good Luck & take you time!
Mike
May 17, 2008 | Computers & Internet
My Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Mar 10, 2008 | E-Machines eMachines Desktop PC
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
883 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
