Projection lamp replacement
My televsion recently indicated lamp failure was imminent so I checked the web for replace lamp prices. Contacted local authorized repair facility, obtained the lamp for just under $300. As instructed I replaced lamp buy the tv still did not work so they took it into the shop an now tell me that the lamp failed again an there was another part out an they did not recommend repair. I asked for a refund of the lamp since the all the web companys list 180 day replacement policys but I was told that is not the policy of this repair facility so I contacted Zenith an they also affirmed that it was not customary to refund for these lamps. Am I being unreasonable to expect a refund? I am now out $300. an have no television. This tv was exactly 3 years old when this occurred.
Always change ballast AND Lamp. cause lamp went bad ballast is stressed to keep lamp working. thats why lamp went out again.DIY's !@#%^&!
Posted on May 03, 2008
  • 84 Answers
The only thing that would burn out another lamp so quickly is if the ballast assy was also bad.
C-Dog
Posted on Feb 10, 2008
Mitsubishi Wd-73638 code 6 red 1 yellow not sure what that is please help
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
May 08, 2015 | Mitsubishi Televison & Video
Lamp of benQ projector switched off suddenly and failed to light again,but the power button is ON and the fan is working,so what are the causes and how to solve the problem?
Hi
It seems like the lamp has failed. The cause of this is because the lamp can only run a certain amount of Hours before it will fail completely. On some projector models you are able to view the expected fail date and on other there is a warning light on the projector itself indicating that the lamp has reached a certain amount of hours and failure is imminent. Replacing the lamp should solve your problem and is usually quite easy to do
Kind Regards,
Oct 23, 2013 | Sanyo PLC-400 projector lamp Projector...
I have a WD-62327 Mitsubishi. The indicator light
You are probably correct, but it wouln't hurt to check the lamp that is in there to make shure. You can download your owner's from "retrevo" and those manuals also give the web site for lamp replacement(toll free number) if you want the original or I found union electronics to have a good price on some of the replacement lamps .
Jul 30, 2009 | Mitsubishi Televison & Video
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Red light
Yes, If Lamp has not been replaced recently then TV need new lamp.
Let me know model number of Sony TV to provide you Lamp number and price info.
Apr 22, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Nov 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Projection lamp indicators
maybe you have lost contact at the lamp circuit! check the CRT circuit and the lamp circuit!
Oct 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
328 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
