Washing Machines Logo
Posted on Jan 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer runs but will not heat properly and when placed on auto cycle and regular temperature it will not shut off and dial doesn't move and drying takes forever
Mike
Level 2:
  • Expert 166 Answers
  • Posted on Jan 16, 2010
Mike
Expert
Level 2:
Answers
166
Questions
0
Helped
90314
Points
408
If it takes several loads to dry on timed dry then the vent from the dryer to the outside needs cleaning, replacement or is smashed behind the dryer.
Our Miele Tumble drier (Touchtronic T8013C) dries and heat fine but the 20 minutes and 40 minutes functions do not heat (only the regular drying cycle). Any one has an answer?
i don't know. first guess is regular drying cycle makes predetermined heat levels and sensor that shuts off heat and dryer when it decides clothes are dry. 20/40 minute
choices may be fan only unless there is a manual temperature control that you can set eg. off/low/med/high..
Dryer works OK on timed dry but doesn't dry the clothes in Auto dry.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :
http://www.ehow.com/info_12203962_check-dryer-thermistor.
GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Jan 07, 2016 • Dryers
Auto cycle does not work timed cycle works fine
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
1helpful
Gas dryer does not dry in "timed Dry" setting
Whirlpool dryer, when set for auto dry low heat, or timed heat, then dryer runs fine, when set on auto dry high heat timer doesn't move, what could be the problem? does it have to be the timer?
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Sep 21, 2014 • Dryers
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
3answers
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
1helpful
Electric Dryer Shuts Off
During the auto-drying cycle, the moisture sensor could be the problem.
If it also shuts off prematurely during the timed cycle, the operating thermostat could be turning the heaters off before the machine reaches operating temperature. Another possibility is that the operating thermostat does not turn off the heaters at all. When the machine heats up, it gets too hot and the high limit thermostat turns the dryer off.
Top Washing Machines Experts
john h
