First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX) Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working! If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322) Hope that helps.
You shouldn't connect the yellow into the green socket. The Red/Green/White sockets are for HD and therefore won't work correctly with your usually RCA cables. Your TV should have Red/Yellow/White RCA input somewhere. If not you may have to use a VCR or DVD player to connect your system to your TV.
First, you need to plug in the A/V cable (the cable with the red, yellow, and white tips) to the back of the Phillips TV. There should be color coordinated plugs to go with the cable. After that, plug the other end of the A/V cable to your PS2, and you are good to go with your audio and video.
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
You shouldn't need to connect your PS2 to your cable box. Both are video signal sources.
However, some cable boxes do have aux or line inputs. In that case you would connect the yellow, red and white plugs from the PS2 AV cable to your cable box's yellow, red and white inputs. Make sure the jacks you plug in to are labelled input or in, otherwise they're outputs and they won't work.
i have a tv that only has the audio out put and video out put as well . and my playstation 2 works on it. just plug the white and yellow ends in to your tv and it will still work without you unplugging any cables. hope this helps.
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
USE a VCR between the PS2 and the Sylvania TV. Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4. Set the VCR channel to Line 1 or Line 2. This should work. I hope it helps you.
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila.
PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable.
I hope this works for you-BCA
