Question about Samsung YP-Z5 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY SAMSUNG YP-Z5, while charging constantly gives nmessage "Low Battery",and it does not work after unplugging and does not recharge either.
  • 6 more comments
  • MissDaffodil Feb 10, 2008
    low battery, wont charge, keeps saying battery low - usb disabled when connected to the pc, been working and charging fine for 12 months, tried all usb ports on pc
  • Anonymous Apr 23, 2008
    battery do not charge either it's connected to pc for a long time. The screen always shows low battery icon
  • Jahve May 02, 2008
    Im having the same problem. Cant get it to connect through USB and cant seem to get it to charge..
  • Anonymous May 05, 2008
    exactly the same - low battery usb disabled - cant charge. tried various cables, ports, pcs, no luck
  • benjamw May 13, 2008
    Same problems as well, also had my around 12 months - seems to be a real problem with the model.
  • ssah26 May 24, 2008
    I've been having the exact same problem. Its been working fine for the past year and a half but its been playing up for a few months, and now, it keeps on displaying the low battery sign and when i plug it in to charge, my computer wont read it, and nothing happens. I've tried it on other computers and it still wont work and even tried another USB port but stil no change. Please help me.
  • aidengeezer Aug 31, 2008
    hey people i dont no if i got tht problem but i haven t used mine for 8 months as i lost the cable i left it for a while and took selling into consideration left it over nite i have somthing and i belive it is charhging roomers go round turn it off put it on hold then plug it in but i cant see that working any better than just plugging it in !!
  • Rayong Dec 21, 2008
    I have the same problem low batterry
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Posted on Jun 07, 2008
I was suffering the same problem with the low battery usb disabled , after trying all usb slots and nothing , i have a usb keyboard that has a pin socket to usb adapter , i plugged my mp3 player into the usb keyboard adapter and it charged the mp3 player enough to get rid of that message usb disabled , and i then plugged it into a usb slot and the mp3 is charging and working properly again ,
hope this helped
Posted on May 04, 2010
  • cmackrell May 04, 2010
    I was going through the same situation with my mp3 player and was not able to charge it due to usb disabled , i had tried pluggin the player into all the different usb slots on the computer and nothing .
    the way to fix this is , i have a usb keyboard that came with an adapter for the traditional pin socket that the older keyboards plugged into . so this adapter plugs into a pin socket but becomes a usb jack for the keyboard , i plugged the mp3 player into this socket as it isnt a usb its a pin socket which charged the mp3 player enough to remove that painful message battery low usb disabled and it can be then plugged back into a normal usb socket ..
    hope this helps everyone
WHERE DO I PURCHASE A REPLACEMENT BATTERY
Posted on Mar 15, 2010
  • coralsoft Jul 29, 2011
    Try eBay - there are plenty there. Alternatively, disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player.
After using my YP-Z5 for about 8 months, all of a sudden I had the same problem yesterday, (low battery, usb deferred) and again today, on two different pc's. This afternoon I tried another usb port on the first pc. The connection screen appeared without any delay, and the battery started charging. The funny thing was that when retrying the first usb port, the player functioned normally as well!
Brent
Posted on Feb 22, 2008
I have the yp z5 model and it wont charge and the comp. wont recognize the device either. im guessing i should replace the battery because all of the components inside are still intact.
Try to take apart the player and disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player. Alternatively, try eBay for a new battery - there are plenty there.
May 03, 2011 | Samsung YP-Z5 MP3 Player
Samsung 1gb yp-z5. wont charge, usb disabled. PS havent got any other usb ports to try, no keyboard additions.
Feb 20, 2011 | Samsung YP-Z5 MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
SAMSUNG YP-Z5 PLAYER NOT CHARGING!
U HAVE 2 RESET IT WIT A LEAD PENCIL IT AT THE BOTTAM IN THE BACK OF THE MP3 PLAYER™ IF THAT DONT WORK I DONT KNOW
Jan 07, 2009 | Samsung YP-Z5 MP3 Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Charging battery
Make sure the hold/lock switch is not engaged - then recharge
May 27, 2008 | Samsung YP-U3 MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Jul 04, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
1,798 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
