Question about Sony Playstation 3 (PS3) Console
Playstation 3 on Sanyo Large Screen HD DT
I have a large screen SANYO HD TV. I have an HDMI DVD player hooked into it. I can access my HD DVDs through AV1. I also have a COMCAST DVR hooked into the TV. I recently purchased a Playstation 3 that I want to also hook into the TV - but I can't seem to figure out how to hook it in. Do I have to go through the DVR?
  • 178 Answers
It would be better if you went diretly threw a video source on the TV. Rn the wires from the PS3 to the tv and then select the source that it is connected to
Posted on Feb 10, 2008
Toshiba HDDVD Player Model HD-A3
well your TV has a 1920 x 1080 Pixels hi resolution is this what you mean?
I would hook up your HDDVD via HDMI to the TV and the regular DVD to Component1 on the TV,
hope this helps
Jan 13, 2008 | Sharp LC-45GD7U 45 in. HDTV LCD
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
How to connect DVR 1600 to LCD HD TV or ATT uverse recorder
has to be scarts, your reciver (sky, cable ect ect) to your dvd recorder, from that to the tv, all scarts, might help, regards mark
Feb 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Sony Playstation 3 (PS3) Console Logo
217 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
