Question about Pioneer PRO-700HD 64" Rear Projection Television
Television not satying on.
The TV worked perfectly for years. I put it in storage and then after 2 years of sitting I plugged it in and it worked perfectly for 5 minutes. Then it powered down and now I can't keep the power on for more tehn 10 to 15 seconds. The main powere stays on but teh standy will not stay on.
  • 84 Answers
It needs to be brought into the repair shop for service. There is nothing that you can do to make it come on. It's just an old set.
Posted on Feb 10, 2008
How-to check a Lamp Ballast board on a Sony KDF-55e2000 TV for proper operation
You cant test them unfortunately. The only reliable way is to swap it out with a known good ballast. They can and do go bad sitting as the capacitors start to dry out from not using them. Sitting is bad for electronics. Buy a ballast from ebay(used known good) and try it. Thats your best bet honestly.
Aug 20, 2016 | Sony KDF-55E2000
Have a phiips tv had it in storage for over a year turned it on an the screen working perfectly but there a hising noise coming from the back of it do no what it is... Its a big bk tv not flat screen box...
hissing noise will be from high voltage regulator, i would suggest to do following:
1. switch tv off
2. remove plug from the wall
3. using air blower (compressor attachment - not leaf one!) blow the dust, especially from high voltage box section
4. connect the tv and switch on
if tv still issue hissing noise - follow 1 and 2 then:
3. remove back cover
4. use air blower again...
5. re-install back cover
6. reconnect tv and switch on
if hissing noise persist - check for blown capacitors on high voltage, replace if necessary, they have nasty tendency to pop if they are too long in storage, especially if tehy were overheated or frozen.
hope this will help you solve the problem, do not forget to vote...
Jan 27, 2015 | Televison & Video
Radio won't power up
Check the power wire to radio. and check the fuse for radio also. If ok, The radio may have gotten moisture etc, from sitting for 2 years. Good-Day!
Aug 21, 2014 | Cars & Trucks
I have a 52" Quasar
Could be anythings wrong with it,must hire a tv troubleshoot and repair.Because doesn't know the causes and the problems was in storage 5 years ago.Tries check all cales wires plugs in connections are tightly connected and no loose connections wires on those PCB boards,might help make the tv it work again.
Dec 07, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Washer will not spin when it gets to spin cycle
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
May 16, 2010 | Maytag Atlantis MAV6451 Top Load Washer
32'' flatscreen (CRT) JVC I'Art tv will not turn on
I remember Jvc put out a service document about changing 2 transistors in the power supply..they are surface mount on the solder side of the pcb. You might not find the parts anymore unless your very tech saavy. Sorry man..
Jul 22, 2017 | JVC Televison & Video
How do I reset a GE model 26gc642 television
There is no reset, when a CRT stays in storage for prolonged amount of time, moisture can build up and when you plugged in, most likely a surge happened, and your tv I'm afraid is dead. use it as an excuse to get an LCD :)
Apr 03, 2009 | GE 19TVR62 19 in. TV/VCR Combo
Dead tv
If this set has been sitting in storage this long theres no telling what could be wrong . Take set to a repair shop.ThankYou for trying FixYa. Have a Nice Day.
Feb 19, 2008 | Televison & Video
TV Problem
Jan 25, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Help K2001UM TV
I'ts possible that by accident someone activated the parental lockout. Your best bet is to locate your instruction manual and find the default code. Also problems(usually with software) can cause the the tv to do unusual things. Leave the set unplugged for at least 24 hours, the see if there is a response with the buttons on the tv. You may be able to reset the set to factory defaults. Scrivitron
Jul 06, 2007 | Konka K2001UM TV
Pioneer PRO-700HD 64" Rear Projection Television Logo
103 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
