Question about HP Pavilion M70 17" CRT Monitor
M70 crt While I'm working on my computer, the monitor will go black for no apparent reason, what will cause this and how can I fix it?
  • wolf1488 Feb 14, 2008
    I did what was recommended, it fixed the major problem of going completely black. Now it just dims to where you can still see it, but its darker than it should be and its a real pain in the butt to look at. Wonder what it could be...
  • 983 Answers
Just check the power cable from the monitor is connected properly or not try reconnecting it...
may be there is some loose contact in power cable............
check the cable which connects the cpu from the monitor is connected properly check whether is there any loose contact try reconnecting it...........
if problem persists then there is a problem with operating system try reinstalling it....
Posted on Feb 10, 2008
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
there are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Jul 10, 2011 | Fujitsu Siemens MCM 173V (White) 17" CRT...
Sony CPD 200SX 17" CRT Monitor: Upon resuimng
Monitor has gone to monitor heaven. time to do some shopping since repair not cost effective.
Apr 04, 2017 | Sony CPD Computers & Internet
Screen is whitish and its blinking with white lines
The Cathode Ray Tube (CRT) can develope a short circuit in the neck area of the tube that will cause this. I suggest that you remove the plastic cover of the monitor, and tap on the neck of the cathode ray tube with the plastic handle side of a screw driver. Be careful while the cover is off of the monitor not to touch any wires or the high voltage wire that connects to the side of the tube. There is very high voltage used to operate the CRT and it will zap you!!
Oct 02, 2010 | HP Pavilion M70 17" CRT Monitor
Overstretched screen
the circuitry to regulate the screen size and the height and width has failed and your crt need service but it would be more expensive to repair than to purchase a new LCD monitor.
the control pots or resistors usually go out on a crt over a period of time and have to be replaced This is very expensive. Also with the pots the capacitors in line with the resistors have to be replaced. Then there are the regulator components such as a LM317 which regulates the voltage to the circuit to keep it at constant voltage for the pots to adjust.
Apr 17, 2010 | HP Pavilion M70 17" CRT Monitor
My moniter viewsonic multimedia series m70 is on but no display is show
then its not ur monitor fault check the systems...remove ram from motherboard and put it again u will get display....
Nov 25, 2009 | ViewSonic E70f 17" CRT Monitor
My crt monitor has a white ghost image to the right. It looks like JPEG artifacts. I've replaced the monitor and I've tried another graphics card, but it's still there. The PC is an HP d325.
A ghost on your screen is usually caused by a second or reflection of the same image getting into your monitor, and the space between the real image ant the ghost is the delay in time or extra distance the second image travels before it is displayed on your screen. It is usually caused by a defective video cable or a cable longer than usual like 8 feet or more. Also is your monitor plugged into the same outlet as the computer, and is the case on your computer as all are possible reasons for your problem. Some times adding a ground wire from monitor to computer can correct problem. This can be a problem that takes some real detective work to find, and all I can do is suggest some possible causes.
Oct 09, 2009 | Samtron 76df 17" CRT Monitor
I have a hp pavilion mx704 17" CRT monitor which starts flickering and blacks out every 5mins or less than that, i have to hit it with the right amount of force on the sides or on the back to make the...
i have experienced this problem before with a nec crt monitor and its permanent and can not be fixed with out having to flush money into it. personally i wold not deal with it. in this day in age era LCD monitors are almost dirt cheap plus if you put it this way which is more valuble to you your health? or your monitor. the reason asking this is because crt monitors outputs a high dose of radiation. partly the reason to produce lcd monitors they dont disapate heat like crts and they dont have all that radiation build up like crt monitors hold. so if you would rather have your health then get a lcd for sure.
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Screen has yellow flashing tint
probably power problem, should be taken to lab for checkup
Dec 23, 2007 | HP Pavilion M70 17" CRT Monitor
HP Pavilion M70 17" CRT Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
